DS21 Setting up manual height control lever system
Results 1 to 3 of 3
    719
    Default DS21 Setting up manual height control lever system
    Hi all,
    Can anyone point to a factory procedure in the manuals for setting up the manual height control system - that is the mechanism of rods and levers that allow you to select the height manually?
    I put it all back as it came out but it's just not working as well as it should - ie. it won't let the front come down fully, and the rear position seems to be adjusted in a less than optimal way.
    When the time comes I'd like to set it up from scratch again if that is possible.
    Kind regards,
    Mark
    Apr 2016
    Bedford, UK
    821
    Hi
    You need Op. D. 430-0 in Volume 1 of manual 814, with Ops DX.437-0 and DX.437-1 in manual 518 also being worth a read (as 518 sometimes imparts extra information)
    Paul
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    719
    Many thanks Paul - much appreciated. I'll give it a read..!
    Kind regards,
    Mark
