ID19b dash clock battery
Results 1 to 7 of 7
    Dec 2016
    Dun Laoghaire, Ireland
    4
    Default ID19b dash clock battery
    Hi...I have an isolator on the main battery - so is there any problem wiring the dash clock to a small 12-volt battery?
    Apr 2016
    Bedford, UK
    818
    No.Other than that you'll need to keep changing the battery.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Feb 2012
    Ongar / England
    868
    Hello, you can bridge the isolator with a fused wire. If you use a small amperage fuse, say 5 amp or less, the clock will run from the car battery. If someone tries to start it, the fuse will blow.
    Like this
    https://www.ebay.co.uk/itm/Discarnec...EAAMXQ~6VQ5BPS
    Easy to knock one up with a small fuse holder and fuse, a couple of ring terminals and a bit of wire.
    10,090
    Should be OK as long as there are no other parasitic loads to run the battery flat. You could add the clock feed wires between he battery terminals and isolator instead to power the clock but eliminate any other loads.
    1960's Jaguar 420 and G had a battery dash clock, but I can't recall if it was 12V or something lower. I can't recall how long that lasted, but the clock will let you know. You will probably need to adjust the clock speed if the small battery's voltage differs to the starting battery voltage, which is only nominally 12V.
    Apr 2016
    Bedford, UK
    818
    Quote Originally Posted by badabec View Post
    Like this
    I read the description on Fleabay: what's the benefit of the bridged fuse to ancillaries blowing if someone tries to steal the car? Is it just a 'tell"? If so, I'd have thought the smashed side window and screwdriver jammed in the key hole would be enough of a clue At least, with the clock stopping, you'd know what time they tried to steal it!
    Feb 2012
    Ongar / England
    868
    They are worthwhile if the radio is coded and to keep any internal alarm batteries topped up.
    I would just reset the clock each time.
    Sent from my SM-J510FN using aussiefrogs mobile app
    Dec 2016
    4
    Many thanks, gentlemen for the advice. I'll sort it.
