Xantia Panel Light Quiz
Results 1 to 7 of 7
Like Tree3Likes
  • 3 Post By JBN
Thread: Xantia Panel Light Quiz
    JBN
    JBN is online now
    1000+ Posts JBN's Avatar
    8,468
    Default Xantia Panel Light Quiz
    Can anyone tell me what the top right-hand warning light is on a 1995 Xantia automatic? It has been flickering when I start the car but then goes away. Tonight it flickered as I was driving and now the car is fluckt.Xantia Panel Lights.jpg
    John
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,099
    From memory, hydraulic fluid level?
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's) Grandma's Taxi
    1974 D Special Manual Sedan ("Moby Dick") Weekend Warrior
    2006 C5 HDI Wagon Auto ("Mephistopheles") Workhorse
    1982 2CV6 ("Gaston") Seasoned Traveller
    1975 GS Pallas ("GiSelle") Shrunken CX
    Armidale
    2,543
    Now you've got us puzzled - I thought the Xantia had died and gone to Citroen heaven, replaced by a Camry?
    BTW - thought you might enjoy this Xantia review - the reviewer lets it slip that he/she prefers the V6 Camry https://www.drive.com.au/used-car-re...E&gclsrc=aw.ds
    Top Rh in the left hand group (as per picture)? Oil level. If your dipstick is like mine (plastic knob has crumbled off the steel 'stick'), then you may be pushing it in too far, giving you a false sense of security re. the actual oil level.
    Alec
    Jul 2013
    Newcastle/ central coast
    2,222
    Thatís oil level and only should be triggered when ignition is switched on you may have a power problem like a stuffed ignition switch common
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    JBN
    JBN is online now
    8,468
    Basically the original Xantia has NOT gone to heaven. I purchased another one very cheap. It has a good donor engine and a younger ZF gearbox. The instruments are "interesting". The oil light in question comes on for quite a while. I added more oil, but it must have had a recent oil change as it was hard to discern exactly where the oil was on the dipstick. I was thinking of adding some old sump oil as that is easier to spot. The fuel gauge was showing about 1/3 of a tank remaining, but the engine wouldn't start until I put in 5 litres. The speedo is sluggish but goes to 70 kph very quickly, regardless of what speed I am doing. This is very scary in 40 kph zones. The speedo is wrong because in school zones doing exactly the same speed as other cars, it still shows 70 kph.
    Anyhow, I will drive it around a bit and then take it to Jason to swap. I will ask him if it is worthwhile changing the auto transmission oil and changing the engine oil/filter before swapping the engines, as I am more confident setting the benchmark straight away with the right filter/oils/levels.
    I like the Xantia and find it a much more nimble car with a better steering than the Camry. I miss the VSX ride (this new one is an SX) but that will return after the engine swap. The instrumentation and brakes are better on my old Xantia. This new one with the "silly spring" is almost as spongy as the Camry. The old Xantia had a length of conduit replacing the silly spring so the brakes were either on or off - no maybe, I'm thinking about it. And the old Xantia's instrumentation worked accurately - I have plenty of written evidence of how accurate the speedo was from speed cameras and the police.
    I will take some time before committing to the engine swap. The old car is with Jason. If I decide not to proceed, the scrap metal value is the same as the flat bed cost to his place so nothing lost. If this new one doesn't work out, I can scrap it and only be $100 out of pocket.
    I have been in this situation many times. Usually its when I am looking a young lady's bum as she walks past, only to be brought to reality as my wife asks "you eating out or do you expect me to cook you dinner?".
    John
    Armidillo, COL and David S like this.
    Ici.
    2,651
    the top right warnig light symbol (orange one) is your coolant. Below that is oil. Mine flashes on start up but its full and doesn't go over 90c and I'm not sure what is triggering it, it didn't flash for most of thhe time I've had it.
    10,094
    ... The fuel gauge was showing about 1/3 of a tank remaining, but the engine wouldn't start until I put in 5 litres. ...
    Mine was a little like that. It wold hand around half for ages and then rapidly drop after that. Likely a faulty rheostat winding on a small board clipped onto the in-tank unit. Also, if you park them on a hill or on a slope with the LHS low and not much fuel in the tank, the pickup (under right rear seat) can be out of the fuel. A bit of a gotcha to be aware of.
