Faulty gear lever switch in 2010 C4GP EGS
Results 1 to 11 of 11
    Feb 2019
    Wollongong
    4
    Default Faulty gear lever switch in 2010 C4GP EGS
    Hi Folks,
    I've had the dreaded "Gearbox Fault" service error come up on my 2010 C4GP EGS but thankfully the mechanic tells me it's just the switch on the gear stick that is the problem (according to error code). The mechanic reset the fault as the error hadn't happened for a few weeks and suggested it may have sorted itself out but the error has returned. Any ideas of what part/process is required to replace it and where a part may be sourced? There doesn't seem to be anything online about the Picasso that I can find and no Haynes manual. I'm keen to do it myself rather than make another trip back to the mechanic if it's relatively simple.
    Thanks.
    mycle.
    1000+ Posts fnqvmuch's Avatar
    port douglas
    1,102
    there is an english forum where the more common faults are discussed at length - 'C4 users'?
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
    Feb 2019
    Wollongong
    4
    Yeah, I've been through there and haven't found any reference to this fault and there doesn't appear to be anything in their archives regarding it. Also, figured I might get better options for sourcing parts locally here.
    THanks
    mycle.
    port douglas
    1,102
    C4 PICASSO - 0560 01 335605A - GEAR CHANGE CONTROL BINACLE SIDE.pdf
    for what its worth part number 2400FP
    or replacement part number 98002210VV
    may help at EAI or Continental Cars
    port douglas
    1,102
    https://www.peugeot.com.au/aftersale...ther-services/
    above should - if you set up an identity - get you into the PSA database; build-sheets, spare-parts exploded diagrams, etc., as well as - for a fee - technical documentation.
    I haven't gone that far myself, but what can be accessed gratis is very useful.
    Jul 2013
    Newcastle/ central coast
    2,222
    What was the fault code you had?
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Feb 2019
    Wollongong
    4
    Awesome stuff fnqvmuch. Thanks.
    dmccurtayne - error on the screen was "Gearbox Fault". Mechanic who did last service said it was something about the switch on the gearstick - which fits with the behaviour now that the error has come back as it sometimes fails to register that the stick has moved and you have to flip it back and forth a few times to get it to change between R, P, A & M.
    Mycle.
    Jul 2013
    2,222
    You need to know what the code was to narrow the fault down properly
    Garage C5 X7 4008
    Oct 2011
    Sunshine Coast, Australia
    55
    I thought the gear change stick fault was caused because there wasn't enough dielectric grease on the connection plug or enough on the contacts of the lever.
    Sent from my SM-G920I using Tapatalk
    port douglas
    1,102
    Those part numbers might be wrong if you have a P rather than N(START) as on my EGS
    Feb 2019
    Wollongong
    4
    It's an N(START) one
