Xantia gearbox oil filler?
    Jan 2011
    78
    Default Xantia gearbox oil filler?
    Hi all,
    Where is the oil filler plug on a Xantia manual (petrol) gearbox?
    I want to check the gearbox oil level but cannot see a filler/level plug anywhere.
    farmpug
    Jul 2013
    Newcastle/ central coast
    2,215
    Model, engine?
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,028
    Seeing I know you have a 2 litre 16 valve, it will be a BE5 gearbox. Look on the end cover and you will see to the rear a larger bolt holding it on - 19mm socket I think. That is the filler and level plug. If you have a leaky driveshaft seal, you will only get about 300ml of oil out of the drain plug, otherwise there should be close to 2 litres in there. If you don't remember giving it an oil change, then drain it all out and give it some new oil. I use a long tube to syphon the oil in from a container sitting on the battery down and into the filler hole on the end of the gearbox.
    The filler/level port on the MLT5 gearbox is on the back of the diff housing and is not easy to access.
    Cheers, Ken
    Jan 2011
    78
    Ah yes, some more information would be useful! My apologies.
    It is a 2l 16 valve and as Ken reminds us it has the BE5 gearbox (I don't actually know this I'm just using Ken's information)
    Thanks!
    Farmpug
    Quote Originally Posted by Ken W View Post
    Cheers, Ken
