DS23 Weber Carb
Thread: DS23 Weber Carb
    Jun 2016
    Newcastle NSW Australia
    120
    Default DS23 Weber Carb
    All jokes aside. Does anyone have a tip for loosening and removing the front driver side intake manifold nut off the base of the Weber carb. Everything seems to be in the way.
    Feb 2012
    Ongar / England
    864
    Hello, starting with the simple, have you taken the rocker/valve cover off? Some have bent the end of a suitable spanner to 90 degrees, a bit like a crowsfoot spanner.
    Everything is always in the way! Just keep taking bits off until you can reach it. Or employ a four year old kid who has a vice like grip. Just wait till you have to remove the starter motor.
    Jun 2016
    120
    I bent a spanner and got it loose. I cleaned the carb by pulling out jets and retainers one at a time.
    I havenít cleaned such a complicated carb before but I think I managed ok. The base is very warped though so I applied a good deal of gasket goo to the gasket in the hope of plugging it. I took a picture...
    Feb 2012
    Ongar / England
    864
    Hello, common problem
    warped carburetor base
