RHB triage
Thread: RHB triage
    1000+ Posts fnqvmuch's Avatar
    port douglas
    1,078
    Default RHB triage
    Asked for diagnostic check asap when dropping off the car for Timing Belt service because I'ld had an engine light.
    haven't got the p-code but apparently it's the throttle plate / body and solenoid arm plastic worn - not locating ...
    and there are traces of a coolant leak from around the Oil pump (?) mounting, behind the a/c compressor ...
    are these known fix-ables to anyone? if so what do i order and when?
    btw its tempting to post this in the Peugeot department as well (sharing - something to consider) but assume the nice people see anyway ...
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
    Jul 2013
    Newcastle/ central coast
    2,219
    There is a fitting in the block up and to the passenger side of the compressor but nothing else pretty common for the arm to pop of you can drill a small hole in the post and put a small wire through to hold it on even my late c5 needed this at about 60k
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    port douglas
    1,078
    is it the 1920QV FLOWMETER that is meant by throttle body/plate
    - is that like a butterfly in there actuated by solenoid?
    Jul 2013
    2,219
    No I take that to mean the egr or intercooler bypass throttle plate on the pipes going into the intake manifold/valve cover
    Garage C5 X7 4008
    port douglas
    1,078
    I remain profoundly grateful;
    0345 G7 AIR DOSER
    I presume?
    They are expensive enough, even from EAI.
