Radiator Vinyl Shroud
Results 1 to 11 of 11
Like Tree4Likes
  • 3 Post By citroenthusiast
  • 1 Post By Secretsenor
Thread: Radiator Vinyl Shroud
    Jun 2016
    Newcastle NSW Australia
    120
    Default Radiator Vinyl Shroud
    Iím about to fit a new vinyl shroud for the radiator intake on a DS23. Before I start I wondered if there was any wisdom I should consider before starting...
    Heat the vinyl?
    Use big staples and bend them manually with pliers or hammer?
    Has anyone gone space age and opted for Velcro?
    Feb 2012
    Ongar / England
    864
    Hello, I used stainless steel locking wire and lock wire twisting pliers to tighten.
    Trouble with Velcro is you either have to stick it on (how long will that last?) or staple it on, so you are back to where you started.
    I didn't find any need to heat the vinyl. You just need a towel on the kitchen table to stop it sliding all over the place, and a third hand.
    Peter
    Apr 2016
    Bedford, UK
    808
    Iím going to strip and returning my original shroud, and I plan to replicate the big copper staples. Somehow. Probably folding them by hand.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Feb 2002
    Coolum Beach
    2,027
    Quote Originally Posted by Secretsenor View Post
    Yes Velcro did seem like a good idea when I installed my new shroud. So I tried it, but somehow it didn't last the distance . Probably got too hot in there for the glue and it became unstuck after a few weeks. It's possible that using a specific glue for that application would work, but I reverted to original fixing.
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    Apr 2014
    Phoenix, Arizona USA
    691
    I drilled every other staple hole to 1/8 inch and used pop rivets with backing washers on the inside. After 10 years, so far so good.
    CXVingtCinq, JohnW and Dano like this.
    John T.
    Jun 2016
    120
    Iím thinking rivets if itís a 10+ year option
    Jun 2016
    120
    I went with Rivets and the existing (original?) metal straps as reinforcement
    CXVingtCinq likes this.
    1000+ Posts CXVingtCinq's Avatar
    Jun 2015
    Narrabri, NSW
    1,019
    Looks good from here.! Well done.
    Cheers, Peter J
    Current - 1974 D Special
    : 1976 16TS
    Previous - 1984 CX 25 IE : 1976 16TS : 1979 12 Virage
    Feb 2012
    Ongar / England
    864
    Hello, I'd like to see the stapler they originally used, must have been a beast to punch through the metal strips
    Apr 2016
    Bedford, UK
    808
    I'm guessing the holes were pre-formed?
    Jun 2016
    120
    No, I used a punch
