Check out the damage to my BX 16 valve front subframe
Results 1 to 25 of 33
Like Tree4Likes
Thread: Check out the damage to my BX 16 valve front subframe
    Wollongong, NSW
    139
    Default Check out the damage to my BX 16 valve front subframe
    Hello everyone, I purchased my 16 valve BX around 2 years ago with a known subframe issue.I've basically just stored it since whilst waiting for it to be eligible for historic registration.Well the time has come so I'm tackling the subframe repair/replacement.I got the subframe out today and the damage is worse than I was hoping for, but repairable, Of course it would be much easier to install a good used on if anyone has one?Otherwise I will just weld up all the cracks and then plate over the top for good measure.As you can see the whole thing has taken quite a lot of hits over the years.Please stand by while I figure out how to post a picture over 100kbBen
    11,231
    Good luck with the picture. I can't even get them up any more with less than 100kb.
    What is going on???
    Moderator? Webmaster?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Wollongong, NSW
    139
    Well either the forum is broken (or possibly my internet is being difficult)No matter how many times I try to edit my post for layout and spelling etc it won't save it, or just reverts back to all bunched up with no paragraphs etc.And it won't let me click on 'Go Advanced' either.StrangeBen
    Wollongong, NSW
    139
    Testinghttps://photos.app.goo.gl/8Aop93Yq7KW3bUnUA
    Wollongong, NSW
    139
    Wollongong, NSW
    139
    Wollongong, NSW
    139
    1000+ Posts Dano's Avatar
    Apr 2012
    1,397
    How does that happen?
    Has the car been involved in a major accident or something? Surely it is not fatigue.
    Dan
    Wollongong, NSW
    139
    Well that's the best I can do for now, the previous 3 links. They work for me but I don't know if you will be able to access them. If not let me know and i'll try something else.It looks like i'm completely unable to edit or delete my posts, not sure what's going on there.Plus the forum seems to only load a page 50% of the time, but if I hit refresh it usually comes up.Ben
    Wollongong, NSW
    139
    Looks like I can't reply to peoples specific posts either...Dano, I wish I knew how it happened.I'm almost positive it's never been in a crash.The car has fairly low kays for it's age, 150,000 iirc, and is pretty straightI'm guessing one of the more substantial hits on the subframe started a crack and from there it just spread with fatigue and stress.It must have been making some nasty noises for some time though, with the front wheels slowly gaining more and more toe out as the chasm opened up haha.Ben
    10,128
    I can see three images, but there are obviously some problems with the forum at the moment. Simply fatigue? Not helped by the damage from being jacked up under the middle. I'm not sure if that's the right place to jack a BX in any case. It may have been torn in one place and the PO simply kept going, not realising how extensive the cracking was becoming and how quickly it propagated. The wheels were obviously still on, so it must have been just fine!!!
    10,128
    Worried about the groaning noises? Turn up the radio!
    FIVEDOOR likes this.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,474
    Maybe the disease that ate your BX subframe is contagious and effecting AussieFrogs.John
    JohnW likes this.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,875
    Quote Originally Posted by Captain Slow View Post
    AF Gremlins at workhttp://www.aussiefrogs.com/forum/citro%EBn-forum/135055-reply-difficulties.html#post1601512
    Every day is a good day
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    That sub frame is a throw away. If repaired it would never get an engineers certificate to allow for a RWC. Buy a replacement and then check it for beginnings of the same situation. I have never seen a Citroen sub frame in such bad condition. Is it the same unit in the Peugeot base platform?
    JohnW likes this.
    Cheers Gerry
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,048
    I don't think you could ever be sure that the wheel alignment using that sub frame would be close to correct. So I think you should replace it with one that has no cracks in the metal and isn't too bent on the bottom from poor jacking attempts. Cheers Ken
    Dec 2018
    Guildford, England
    33
    There isn't a hint of corrosion in one of the photos - that damage came from impact which means all of the metal has had it. New sub-frame required (and check the seatbelts at the same time because they're probably stretched...)
    Dec 2018
    Guildford, England
    33
    Maybe the wheels hit a deep pothole - looks like the stress loading is pretty even from one side to the other..? So check track-rods, etc as well (basically, anything outside the body that could have taken the impact from the wheels).
    11,231
    Good grief, what a mess.
    Throw it away. There must be a BX somewhere that can be a donor.
    Faulconbridge
    2,682
    Or change the station......
    David S likes this.
    1000+ Posts driven's Avatar
    Apr 2005
    1,550
    What is rest of car like underneath? It looks like a piece from a Paddock Bomb
    Ici.
    2,655
    Denton at European Autocare Penrith might have something hiding in the graveyard, or check this out, https://www.chevronics.co.uk/product...ame-bx/someone somewhere will be able to provide one, there must be a few with some grass growing through them.
    CitroŽn Tragic UFO's Avatar
    9,791
    Any chance it is an ex race car and has had a few whacks?
    Ici.
    2,655
    Ici.
    2,655
    having real problems posting, what is going on? won't let me edit or delete post. Just freezes up...the part at Chevronics in UK is in sub menu of BX parts suspension, used part and I guess the freight would be a tad up there as that subframe would weigh 25 kilos? so about $400to send at a guess. About $7-800 all up possibly?
