C5 X7 rear brake disc & pads recommendations
Results 1 to 23 of 23
Like Tree3Likes
  • 1 Post By seasink
  • 1 Post By bluey504
  • 1 Post By seasink
Thread: C5 X7 rear brake disc & pads recommendations
    Feb 2014
    82
    Default C5 X7 rear brake disc & pads recommendations
    I'll be up for new rear pads and rotors soon for my 2010 C5 Comfort 2.0 HDi (RHH engine). It has done about 168,000km (who knows how any pads and rotors it has had already, have just bought the car) and you can see there's not much meat left on the pads and the rotors appear to have worn quite a bit; there a ridge on the the outer edge (is that eniough of a rule-of-thumb sign that replacement is needed or should I measure rotor thickness?)
    I don't want or need OE. There are a few choices on eBay for about $200 all up (set of pads and rotors), although I wouldn't necessarily buy those. Any recommendations on brands, and has anyone tried dust-free pads with any success?
    Fellow Frogger! CC1701's Avatar
    Melbourne, Sendai
    147
    Edit: Sorry just checked. Not available for C5 :-(
    REMSA UC (Ultra Ceramic) Pads & REMSA rotors
    Use in combination for the best longevity
    Highly recommended from experience on several cars
    No dust
    No fade (not really going to on the back anyways)
    Great feel
    Work cold or hot
    Reasonable price
    Excellent performance
    9,334
    It isn't a difficult job if you have the tools, to rewind the handbrake/piston, and a Torx socket for the caliper. Online is probably the cheapest way to get a Chinese rewind tool, as Euro trade ones cover too many cars and are expensive.
    Have you priced the discs and pads locally, eg EAI at Thornleigh? Postage of heavy stuff is expensive. Original discs have an anti-rustng coating over the non-friction part, while some, like Italian LPR, are plain iron. Both types work just the same. There's a how-to account here in AF.
    I see the point about brake dust, but it's the fronts that get really dirty.
    Sans_sagesse likes this.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,272
    I find the anti-rust coatings are just OK with normal driving but a quick spirited drive and they evaporate as fast A; A pollies promise, B; Regretful Four Pillars Bankers and C; Than a Cold Beer on a Hot Day.
    Just my worth.
    Brendan.
    Melbourne, Sendai
    147
    The EAI rotors are quite ok. The anti-rust coated ones we've had from them are painted with silver heat proof paint. works great and lasts for years.
    From past experience have found the EAI pads to be less than good. Their entry range has squeaked on 3 cars, whilst their premium ones are nothing special in way of performance, but would be OK on the rear though. But they are very dusty leaving wheels black.
    9,334
    Do you remember the brands of pads you used? I've used Valeo from EAI without trouble on the C5.
    UFO likes this.
    Melbourne, Sendai
    147
    Not sure what pads the C5 has. Haven't worn them out yet :-)
    Had the base Valeo from eai pads on peugeots and a renault, all 3 squeaked and/or squealed. Their premium pads were ok though, just dusty and faded (front).
    9,334
    Squealing often comes down to how they are fitted - do they grab briefly and release creating a vibration? Arrissing them helps.
    Jul 2013
    Newcastle/ central coast
    2,222
    Make sure you locate the handbrake cables correctly after the job is done otherwise it can become very expensive. Also you can leave the car without the handbrake coming on by releasing it with just the ignition on if you didnít know already.
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Melbourne, Sendai
    147
    thanks, but the my comments about eai/valeo pads relate to vehicles in the distant past.
    have been using the remsa ceramic pads successfully for many years now; - great performance, no dust, zero noise.
    Feb 2014
    82
    Thanks all for the suggestions.
    Will probably just go to EAI or Dapco for both pads and rotors. It seems that EBC have low-dust C5 pads in the UK, but not available from the local distributor.
    I've seen the how-to guide, v useful but I'm hoping that I don't have to bleed the brakes to release the caliper... I can cope with that, just seems another layer of time on the job.
    Although a bit apprensive about the elec park brake, at least I have the guide here and a rip-off of the (not all that useful) factory service manual.
    The brake pads on my wife's C5 X7 hardly emit any dust, mine are terrible, front and rear. I'm fussing about brake dust only at the rears because now is the time... I'll do the same with low-dust fronts when they are due for replacement.
    9,334
    Don't undo the brake hose from the caliper, and be especially careful to disable the hand brake. If it goes off unattached it de$troy$ itself. When you wind in the pistons, keep an eye on the rising level in the fluid reservoir.
    10,094
    The factory pads do seem to create a fair amount of dust, but aren't always prone to squealing. Hosing the dust away regularly can help reduce squeal and sometimes cutting a slot in the pad face can help too.
    Some models you need to wind the pistons back in the same direction, while others you need both left and right hand thread tools. Check the windback direction before you inadvertently pop the piston out. I suspect C5 may be opposite directions left and right.
    If you want to be really sure about the electric handbrake, disconnect the battery.
    Feb 2014
    82
    I've had to park this job for a couple weeks, too much work happening now and I'm not driving the car vey much anyway, so not worried about running out of pad material. Also want to research some more about low-dust pads, I'm not getting any joy there at the moment.
    My plan was to revisit all the pad/rotor replacement guides (there were a few when I Googled it) and the factory repair manual before I start. I read somewhere that the tool for replacing angle grinder discs was the right size for winding in the calipers. I thought it was clockwise to wind in for both sides.. but will check.
    Yes there's chat somewhere, I think in the factory manual, about waiting 15min after ign off for the ECU to remember settings then disconnect the battery. It looks like the C5 has a clever quick connect +ive battery cable end too. I really don't want to work out what to do when the park brake engages with the calipers removed...
    Feb 2014
    82
    Thanks to CC1701, I now have a local source for not only low-dust pads, but also some rotors to suit my C5. I have never heard of Fremax rotors, but people out in internet land say that they are Brazilian and an adequate replacement for OE (adequate is my word, they said words to that effect). Good prices, too. Who would've thought to buy parts for a French car at a place called Japanese Auto Parts? I'll report back once I've fitted the new brakes and used them for a while. If they are good, I'm tempted to change the fronts before they're due...
    https://www.ebay.com.au/itm/Fremax-R...81fc%7Ciid%3A1
    https://www.ebay.com.au/itm/Remsa-Ul...81fc%7Ciid%3A1
    CitroŽn Tragic UFO's Avatar
    9,785
    FWIW - the last set of disks I put on the front of the C5 were Borg and Beck and I used Valeo pads. Followed the instructions re cleaning the anti rust film off the disks before fitting, made sure Mrs UFO knew to allow them to bed in and they have been perfect 15,000 km or so later. Dust levels have been quite acceptable. The last disks were Valeo (I think) and had warped - or at least one. Wasn't worth getting them machined.
    Apr 2011
    Albury, NSW
    22
    Quote Originally Posted by Sans_sagesse View Post
    A very late reply, but may be useful for others...
    I just bought:
    Brembo Brake Pads (DB1763) for $74.52 AUD from brakesdirect.com.au
    Brembo OE Brake Rotor Pair Rear 08.8682.11 for AU $155.95 from sparesbox on Ebay.com.au
    Both these are specific for the C5 X7 with electric handbrake.
    May 2015
    Newcastle
    592
    Apart from rotors, is there anything else that would cause a shudder through brake pedal under heavy braking? There is still plenty of wear left in pads and rotors. Do they still machine rotors?
    Apr 2013
    Essendon
    699
    Quote Originally Posted by turnbull151 View Post
    Apart from rotors, is there anything else that would cauusesa shudder through brake pedal under heavy braking? There is still plenty of wear left in pads and rotors. Do they still machine rotors?
    Yes, it's called ABS doing its job. And a second yes, you can have discs machined.
    Armidale
    2,543
    I agree with JAJEA - if the shudder is under heavy braking it is most likely the ABS. The fact that you are noticing it suggests that your tyres are nearing the end of their life (or that the tread compound is very hard).
    If it were warped disk rotors, my experience is that you would generally feel it under light braking, and through the steering wheel (not usually through the brake pedal), as it is usually the front rotors affected. As to machining, usually not worth it, as they will likely warp again - especially as machining leaves them significantly thinner!
    My XM (purchased earlier this year) came complete with warped front rotors. Certainly no point in machining them - they were already well below minimum thickness!
    Alec
    May 2015
    Newcastle
    592
    I probably should have said braking at speed, rather than so much heavy braking. Only started occurring a couple of months ago. New tyres fitted last week and no difference. Tyre fitter said there is plenty left in rotors and pads. Tend not to notice it driving around town.
    9,334
    Don't assume that the front wheels are doing it, if it happens at speed with moderate braking. Back discs/pads can judder too. It is often misalignment or uneven wear. One cause is a little corrosion on the steel hub causing a small misalignment of the disc. It should be removed when discs are fitted.
    PS I usually check run out with a dial gauge after fixing discs. It has been a waste of time in recent years, but it's simple insurance.
    Melbourne, Sendai
    147
    Electronic Parking Brake Release
    FYI John
