CX fuel problem
Results 1 to 23 of 23
Like Tree4Likes
  • 1 Post By gerrypro
  • 1 Post By The Basilisk
  • 2 Post By PROJET_L
Thread: CX fuel problem
    Sep 2012
    11
    Default CX fuel problem
    I did post in the WTB section re. fuel pump for a CX 2400. However, thought I would post here to capture the brains trust further.
    Trying to get a 2400 Pallas ready for sale.
    Unfortunately there is no fuel being pulled up from the tank.
    Pretty sure its the fuel pump.
    Putting out feelers for anyone with a spare pump laying around.
    However I have also noted:
    Did the fuel in the carb trick to begin with as it hadn't been run in quite awhile.
    Pump wouldn't prime. Filter was not filling. The line from the tank to the pump is dry.
    Put an extension onto this line so I could suck the fuel up. No luck and a head ache.
    Could be blocked down the tank end?
    When sucking on the line you can hear it bubbling.
    Forgot to mention the pump is delivering a pulse to the carby side line. Not sure how strong this should be though.
    Also the intake side hose seems to be cracked a little on the end, could it be sucking air. hmmmm.
    Any help is greatly appreciated.
    Wish to sell this car soonish.
    It is a an '82 Pallas 5 Speed which is in good nick.
    Jan 2018
    melbourne, australia
    64
    My mate had a similar problem in his GS. Try running a line from a bottle of fuel straight into the fuel pump and then cranking, that way you will determine whether it's a problem with the lines or with the pump.
    Wishing you all the best in getting the CX going.
    79 cx2400 pallas c-matic
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    Pull out the tank and drain it until it is clean. Then check the fuel pick up in the sender unit. It has a very fine screen and will clog easily if there is foreign matter in the fuel. ( Three hours waiting for a tow on the Eastern freeway is how I learned about this problem). Remove the pump and test its valves by the suck and blow method. Pressurise the inlet with the pump immersed in petrol and see whether there are bubbles coming from the shaft, if so the diaphragm is perforated and the unit will need replacing.
    Cheers Gerry
    11,231
    I fitted an electric fuel pump on the inside RH mudguard (actually skp fitted that one). Wonderful as you use the pump not the starter motor to fill the carbie.
    Not arguing with any of Gerrypro's advice, I'd add - pipes and filters are critical too. But for a car used less than daily, an electric pump is cheap and effective.
    Good luck with the sale. CXs should be worth more than you'll get, but that is a separate discussion....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Sep 2012
    11
    Thanks for the replies fellas,
    I fitted a siphon pump to the line running to the tank to see if I could draw fuel up. No luck.
    I have added around 10l of fresh fuel so the pick up must be submerged now.
    I reversed the pump and blew down to see if I can hear it bubbling in the tank.
    But there is more a loud hiss coming from the left hand side rear. Shes up against the garage tight so hard to get there.
    I assume its a hard line from engine bay to tank. But it sounds like a perforated hose hissing at the back.
    Any diagrams would help if available.
    gerrypro the car has a tow bar fitted so it will be a SOB to pull the tank out whilst grounded.
    I pulled the pump off but I think its ok. Pulling it off was difficult, reinstalling is impossible without a 13mm ratchet ring spanner it seems. Tomorrow to the tool shop at lunch time.
    Then i can get it up and put some jack stands underneath to find the source of the apparent hissing.
    3,158
    Quote Originally Posted by PROJET_L View Post
    One needs universally jointed wrists and elbows. You cannot clean the fuel pick up without removing the tank. What year is the car? Mine is 1978!
    PROJET_L likes this.
    Cheers Gerry
    Bendigo Region
    17
    My 2 cents:
    Simplest way to get it started to be able to move it, access tank etc (in my opinion) would be to run a fuel line from a jerry can to either the pump input (simplest, if you think the pump itself might be serviceable enough), or straight to the carb using a temporary electric pump. You could even just set up a siphon with the jerry can on the roof (obviously all normal safety considerations for working with fuel / electrics etc must apply!). Ideally you also run the return line to the jerry can, or block it off (if you just set up a siphon), but to run it long enough just to move it you would just be pumping excess to the tank if you leave the return line as it is.
    My 78 2400 Super (import) has an electric fuel pump somewhere down the back, both my 1980 2400s just have the mechanical pump (I think). Obviously you don't want an electric pump to suddenly activate with the outlet disconnected! And I would think that even if it's not pressurized it would be safest to block off the line from the tank while doing any of the above.
    I have a cheapy elec fuel pump I bought a while back from the eBay, and along with a few metres of fuel line it's helped start and move many a carbed vehicle, as well as draining stinky stale fuel. However I wouldn't install it as a permanent pump as last time I used it, it was starting to weep fuel from the pump body. So - might be time to bin that one :/
    Good luck with it
    11,231
    This way you put fresh fuel in the carbie too. Good idea I reckon, done with due care of course....
    Sep 2012
    11
    OK investigation complete.
    Did the Jerry can into the pump with a little fuel in the carb.
    Once I had reinstalled the pump that is. What a SOB of job. I came to the realisation that the CX engine
    bay is designed on a principle that mimics a teenagers bedroom. Sh*t everywhere.
    Ran well, seeing not started properly for a few years.
    She jumped up straight away. Set it to high and placed axle stands under the two points at the rear.
    So pump is good. It must be the hissing sound I get when pumping air back to the tank.
    Got the missus to do the siphon pump to try to locate the sound. Must be the hose that joins the line
    to the tank. Am I correct in assuming there is a rubber line as a vibration isolation between the tank and
    the hard line that runs the length of the car?
    Am I also correct that rectification will require dropping the tank?
    3,158
    Yes! Rubber fuel hose from sender to plastic line. Yes! You will have to drop the tank.
    Cheers Gerry
    Sep 2012
    11
    Thanks GerryI thought you would say that.Drain point is at the front of the tank?How are the straps released?
    Sep 2012
    11
    All done,
    rubber hose to the tank had the consistency of putty.
    Car is running now, however the fans don't seem to want to play.
    Turned it off before it got hot.
    Next thing to sort urggggg.
    CXVingtCinq and JohnW like this.
    10,128
    A common no fan culprit will be the little button sensor on a bracket behind the radiator. If you short the terminals and the fans run, it may be dodgy. If you switch the A/C on, the fans should run at high speed, which will tell you the relays (most likely near the battery dog's breakfast) are working.
    11,231
    They have a curious system, running fans in series for low speed and in parallel for high speed, with a wee bunch of relays here and there around the battery and under the LH headlamp. I've replaced both the button sensor that works off air temperature AND the one that screws into the radiator. All works well, at present.....
    16,717
    Before you go to all of this effort. There is a fuel filter hidden down infront of the petrol tank. You will need stands to get safely under there. Change this before going any further.
    shane L.
    Sep 2012
    11
    shane L.
    Hi Shane,
    already done this. No filter between hard line and tank.
    16,717
    Hi Shane,
    Has it been removed? There should be one hidden behind a shield. It is a standard plastic crappy type filter that is probably 40years old! It is underneath the car, just in front of the fuel tank.
    3,158
    Probably removed Shane! Mine does not have one at this position! If there is a bad load of fuel the gauze on the pick up is so fine that it will block long before the muck even gets to the in line filter.
    Cheers Gerry
    Sep 2012
    11
    Well all seems to be going well.... I said to myself last night, time to move her out and give it a wash. Has been in dry storage for 8 years.
    Starts on the button and runs for approx 20sec and dies. F*ck it I said, time for a red.
    Tonight I went back to her and she does start and run on full choke, revs rise to 1500 and then dies.
    First two attempts she back fired on me too.
    Help!
    Carb issue maybe?
    10,128
    Carby is likely. Is the idle solenoid connected? It's a single spade connector at the back of the carby. It won't idle without it working.
    16,717
    I have never seen an idle cuttoff solenoid that works. Most have had the idle adjusted so it idle poorly at higher revs and runs on when you switch it off. The fix is to pull the plunger out of the solenoid. That doesn't fix the running on though
    Sep 2012
    11
    With AC on both fans run on high. How do I short the terminals to check the button sensor?
    and if so where do I go about getting a button sensor?
    Tnx in advance
    16,717
    Tnx in advance
    They are a series parallel circuit. Most failures will end with 1 high speed fan and no low speed. It is almost always the wiring connections onto the relays that is the issue. The fan units themselves are usually fine
