DS - panel thickness for welding?
Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By gerrypro
  • 2 Post By Dano
Thread: DS - panel thickness for welding?
    Apr 2016
    Bedford, UK
    808
    Default DS - panel thickness for welding?
    I'm sure it will have been covered here before, but i couldn't easily find anything. How thick are the body panels (doors and wings) on a DS please? Was it consistent through the Ds lifetime, or did thickness/ quality reduce near the end of production?
    Paul
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    16,615
    Always very thin ... not as bad as a 2cv (that is like trying to weld aluminium foil). I'd have to measure one. Probably 1.6mm ?
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,128
    Most external panels are about .8mm. We used 1mm cold rolled deep draw to fabricate a replacement boot floor.
    1.6 is very thick!
    Dano likes this.
    Cheers Gerry
    Apr 2016
    Bedford, UK
    808
    Thanks gents. I know that modern car panels are only about 0.8mm - which makes them tricky to weld. I just wasn't sure whether, being older, the DS panels were slightly thicker. Even a step up to 1mm makes a big difference in terms of welding.
    10,021
    Door skins are made of a heavier gauge steel than the door frames. They have (some) strength due to the shape. 1mm will suit most of it.
    Apr 2013
    Essendon
    692
    1.6 is very thick!
    Shane is thinking of a Simca Gerry! Boy that "Some car this Simca" had thick panel - never seen anything like it since. It probably was in excess 1.6 mm. Without measuring 0.8mm would be about right.
    John
    1000+ Posts driven's Avatar
    Apr 2005
    1,516
    Simca was a real dud, every panel was welded onto another
    3,128
    Quote Originally Posted by JAJEA View Post
    John
    I have done some repairs to D front Guards! .8mm is the thickness.
    Cheers Gerry
    Apr 2013
    Essendon
    692
    Come on Driven - it was not a dud. Did it not win the Armstrong 500 some years back!
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,767
    In 1960, class win in Class B, not only the win, but second and third as well and the leading Simca was only three laps behind the Class C winning Peugeot 403
    Every day is a good day
    1000+ Posts Dano's Avatar
    Apr 2012
    1,360
    There is panel steel and mild steel. Two completely different materials and they work/form/weld differently.
    I am no expert in this area, but was advised by an engineer who's opinion I value, that I should use cold rolled panel steel when patching forming panels on the 404.
    BRIGHT SHEET
    AS1595 is the standard grade steel in Bright Cold Rolled Sheet. Cold rolled sheet is sheet metal that which has been rolled to thickness at a low temperature in a continuous cold rolling operation. This process will produce steel with closer dimensional tolerances. Cold rolled sheet is a workable/soft material that is used in panel repairs on cars. It has no scale and a bright finish.
    https://handysteel.com.au/sheet-metal-bright-sheet
    Just one, of a number of sites that have information on the topic.
    Hope this helps.
    Dano
    COL and gerrypro like this.
    Apr 2016
    Bedford, UK
    808
    All very helpful thanks! I've bought myself a welding machine off Ebay and, at it's lowest setting, is running at 20amps. So I'm hoping that, (with lots of practice on my part!) it should be able to cope with 0.8mm metal.
