SM camshafts
Results 1 to 9 of 9
  • 1 Post By citroenthusiast
Thread: SM camshafts
    Dec 2010
    Wollongong, NSW
    497
    Default SM camshafts
    Hi All,
    My Sm appears to have severely worn camshafts. The intake is quite peaky/shaft and the exhaust is nowhere near as sharp and has scratches. I guess they are supposed to be the same sort of shape???
    Can you advise where to get replacement ones from please, or is it easier to get them built up again?
    Thanks, Erik
    7,460
    Why couldn't you get them reground? Which engine? I assume they're solid lifters, which means you could reduce the base circle diameter of the cam lobe slightly and fit thicker shims.
    16,424
    this is probably what the profile of the lobes should look like ..............
    https://www.ebay.com/itm/Citroen-SM-...-/222691776902
    Dec 2010
    Wollongong, NSW
    497
    Yes i saw those and no mine don't look like that. Is that a reasonable price to pay for them or should I look at getting them reground as Peter suggested? I am new to regrinding cams so that is why I haven't investigated it.
    Erik
    Apr 2014
    Phoenix, Arizona USA
    676
    FWIW those are 2.7L cams. 3.0L, IE, and Merak cams are different....
    John T.
    Dec 2010
    Wollongong, NSW
    497
    My engine is a C114/1 no: 250.368
    So what would that make it?
    Apr 2014
    676
    USA model, 2.7L automatique
    John T.
    Apr 2014
    676
    By the way, the 2.7L intake is much sharper than the exhaust. Scratches are not good, but are there pits at the peak?
    Cams can be reground, however, there is a high rate of regrind failure, the Italians back in the day seemed to make camshafts out of recycled coat hangers or something......
    JohnW likes this.
    John T.
    7,460
    Given you have to take them out anyway, take them up to Camtech at Caringbah and get them assessed. My friend Malcolm is a straight shooter and will tell you exactly where you stand.
