Suspension cylinder caps
Results 1 to 21 of 21
Like Tree10Likes
  • 4 Post By marc61
  • 1 Post By badabec
  • 2 Post By GreenBlood
  • 1 Post By UFO
  • 1 Post By citroenthusiast
  • 1 Post By marc61
Thread: Suspension cylinder caps
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    330
    Default Suspension cylinder caps
    Came across some good plastic caps with the right thread (M36x1.5) to fit the suspension cylinders etc and stop muck getting in when working on the car with the spheres are off. Theyíre acrylic, come with a rubber o-ring and screw in dead easy by hand.
    Cheap as well, just over 4 GBP for 10 off including postage from China
    https://www.ebay.co.uk/itm/LOT-10-Mu....c101006.m3226
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Feb 2012
    Ongar / England
    812
    Ordered. Good job you get 10 of them, I stand a fighting chance of finding a couple when I need them.
    Sent from my SM-J510FN using aussiefrogs mobile app
    UFO likes this.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    536
    They look the goods for keeping dirt out of suspension cylinders , will order some for that purpose .
    Do they look good enough to use as an oil level plug on gearbox’s and diffs , would be much easier to get oil level at a glance rather then removing plug and then cleaning up the oil that escapes . But are they reliable enough to trust to keep the oil in.?
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Jul 2013
    Stamford, UK
    330
    They’re made out of acrylic so they’ll start softening if the gearbox oil gets much above 90C. I’m guessing it probably does, especially on a long run in hot weather.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Pearl Beach NSW
    536
    Quote Originally Posted by marc61 View Post
    Thanks for for the advice , I was thinking the problem might be the acrylic would become brittle over time . Will just check the oil the old fashioned way by taking plug out.
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    CitroŽn Tragic UFO's Avatar
    9,668
    Quote Originally Posted by Rally View Post
    As a well known Cit Club Sage says "if it ain't broke, don't fix it". I eventually learned my lesson.
    Apr 2016
    Bedford, UK
    666
    I guess the issue will be whether or not the black 'O' ring' and acrylic are resistant to LHM/ LHS.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Apr 2014
    Phoenix, Arizona USA
    659
    Not sure about the black O-ring, but acrylic has very good compatibility with mineral oil.
    https://www.eplastics.com/blog/chemi...lic-plexiglass
    Polycarbonate, on the other hand has very poor compatibility with mineral oil.
    John T.
    Jul 2013
    Newcastle/ central coast
    1,762
    Do they look good enough to use as an oil level plug on gearboxís and diffs , would be much easier to get oil level at a glance rather then removing plug and then cleaning up the oil that escapes . But are they reliable enough to trust to keep the oil in.?
    You can get ones for carbies so you could assume if they donít leak with fuel ?
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Jul 2013
    Stamford, UK
    330
    I’ve just submerged one in LHM, will see what happens to it in a few days time.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2016
    Bedford, UK
    666
    Nice one.
    8,161
    The use for these is surely only to keep dust and dirt out of suspension cylinders with spheres removed, you could just throw the seal away - you would never pressurise the system with them fitted, would you?
    JohnW and UFO like this.
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    9,668
    You beat me to it. Use for storage/dust protection only.
    GreenBlood likes this.
    Jul 2013
    Stamford, UK
    330
    Yes absolutely, I can’t see what else could be done with them.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Pearl Beach NSW
    536
    It would be useful if they made a female version for keeping spare spheres clean and thread protected while off the car , but have not being able to find any.
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Apr 2014
    659
    You can use a standard Caplug type SC (sleeve cap) size 1-3/8. They are flexible so you can push them over the threads and they will stay put.
    JohnW likes this.
    John T.
    9,670
    The best sphere caps are the rubber boots that some spheres, factory from memory, came with. The older pressed aluminium caps were OK too and can be saved and used. The plastic caps that come with some of the aftermarket spheres like UFHS have a split line down the side and tend to fall off unless you put a tie around them.
    Perhaps, try something like these plastic caps?
    https://www.ebay.com.au/itm/332530500627
    Maybe, they need to be a fraction larger to fit the thread?
    Feb 2012
    Ongar / England
    812
    Hello, I keep my spare spheres in plastic carrier bags, cheap (shops have to charge 5p each in UK) and cheerful.
    9,668
    Use the lids of 2l fruit bottles. I used to drink Berri brand until I realised just how much sugar I was consuming each morning (eek!) and changed to tap water. However the lids of these types of bottles are just right for push on caps for spheres. Milk carton lids aren't deep enough.
    Jul 2013
    Stamford, UK
    330
    Nice one.
    Confirming LHM has had no effect on the cap or the o-ring after a couple of weeks of being submerged
    UFO likes this.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2016
    Bedford, UK
    666
    Noted thank you
