SM - right hand drive - help !
Results 1 to 12 of 12
Like Tree10Likes
  • 1 Post By ARCHRIVAL
  • 1 Post By pugwash
  • 1 Post By UFO
  • 1 Post By forumnoreason
  • 6 Post By jonf
Thread: SM - right hand drive - help !
    Jun 2012
    north fitzroy, victoria
    185
    Default SM - right hand drive - help !
    SM accelerator has gone limp.....
    no Viagra jokes please
    OK, so I have been somewhat slack. Or distracted. Maybe it was the DS23 headlights.... or the Light 15 brakes.... and so on.
    But i finally got around to dismantling the drivers side [off side] inner covers of the wheel arch and replacing the battery.
    wow that was fun, not!
    then, upon turning the car on.... hooray! it starts.
    But..........
    first time i pump the accelerator in about a year there was a "snap" sound and the pedal went floppy.
    the car is a rhd McLeod conversion [the very first one i believe]
    at the back of the accelerator there is a rod connected at right angles to a steel tube that seems to enclose a shaft and a right hand crank that disappears and must connect somehow through the firewall to the cable
    but it is impossible to see what is going on there. - it seems to be on the other side of the firewall
    if i push the accelerator all the way to the floor it transfers some movement to the cable, but for 90% of its travel it has no effect at all.
    does anyone know? can you save me a lot of time and effort before i dismantle everything?
    is there a spring? has it become dislodged? is there a broken part? the bell crank? a connector? a weld that has given up?
    From the engine side of the firewall, I cannot see down. The heater box [i think that is what it is] is in the way and it looks like it will be a ghastly business to dismantle and remove it so i do not want to unless it is 100% necessary.
    Any Frogger able to shed some light on this?
    and before anyone suggests i check the parts book or the manual IT IS A RIGHT HAND DRIVE car - it is not a standard mechanism and has been adapted for the steering conversion.
    and McLeod has closed down so i cannot ask him!
    in eager anticipation..... I await your collective suggestions or advice.
    if there is no other solution I will just have to bite the bullet and start undoing the heater machinery and swear a lot.
    cheers
    Jon in Melbourne
    CitroŽn Tragic UFO's Avatar
    9,566
    Perhaps one of the other RHD SM owners could jump in on this one.
    BTW - Pretty sure yours is not the first one. I think that honour belongs to Pajamas.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    326
    Not sure about RHD, but the only way to see is to jack the front well up, put it on stands and get right underneath and look up. On the normal LHD the throttle cable is connected directly to the throttle pedal lever with a ball joint type end and the same to the bell crank near the carbs. Maybe that was replicated for RHD with a longer cable or an extra mechanical link between the pedal and the cable?
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    NORTH PERTH W.A.
    815
    I beg to differ my 1975 ie was peter mcleods first and not his best
    UFO likes this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,856
    Jon,
    This picture might help. I saved this off the Peter McLeod website before it disappeared.
    If you take off the RHS wing, you will find the lever to cable connection and also get a really good view of the battery. I have more pics of the conversion process if you would like them.
    Cheers, Ken
    Jun 2012
    185
    thanx ken
    private message sent and really appreciate it
    i think i need to jack the car up and remove the shrouds under the motor and have a poke around before removing the guard
    cheers
    jon
    tweed heads
    1,439
    Ken ws post about removing the rhs wing to see the cable connection .isn't that were you just were changing the battery ,any chance something has come adrift during that operation .pugs
    UFO likes this.
    Jun 2012
    185
    Ok so here is the problem.....
    the weld has given up...... the weld that connects the vertical shaft behind the pedal and connects it to the horizontal tube that goes off to the throttle cable has failed.
    photo available if anyone wants to see it but is too big a file to up load
    now I have to dismantle it all to re-do the weld.... grrrrrrr
    any advice welcome
    jon
    Armidale
    2,110
    Could it be glued in situ with an epoxy adhesive? I'm not able to recommend a product, but this site is quite informative as to different types, strengths etc.
    https://www.permabond.com/2017/07/21...oxy-adhesives/
    Alec
    9,566
    Quote Originally Posted by jonf View Post
    any advice welcome
    jon
    Look on the bright side. At least you've found the issue and it sounds like you're capable of repairing it. Many of us have been caught by the "but I just had access to that before I put it all back together".
    JohnW likes this.
    Ici.
    2,436
    benefit now is you can improve upon the parts and make it more reliable.
    UFO likes this.
    Jun 2012
    185
    update.... Alec [Armidillo] wins the prize
    i got the air die grinder out and with some circus contortions got into the confined space and cleaned up the old welds
    then tried the two-part epoxy metal glue JB Weld from Repco
    first time i tried to be neat and thus did not use a lot
    but my mate the mechanic Alex said to glue a patch plate across the end join
    that did not work
    so second time i used a LOT of glue and smeared it everywhere i could
    so far it seems to have held
    thus Alec Armadillo you have my eternal gratitude as it saved me either thousands of dollars or days of aggro
    now that the car is running again i can try to source the LHM leak!
    hooray to Aussiefrogs, hugely helpful
    jon
