Bohams Auctions
Results 1 to 16 of 16
Thread: Bohams Auctions
    Fellow Frogger! robo's Avatar
    184
    Default Bohams Auctions
    https://www.bonhams.com/auctions/251...ngth=10&page=6
    1000+ Posts CXVingtCinq's Avatar
    Jun 2015
    Narrabri, NSW
    1,019
    ?? It says ID 19 and yet the motor is quoted as 2500 EFI.?? Not much originality even if you get the old 1911 motor in a box with the car.
    Does look beautiful however. But $200K to $250K is a lot of cash......
    Cheers, Peter J
    Current - 1974 D Special
    : 1976 16TS
    Previous - 1984 CX 25 IE : 1976 16TS : 1979 12 Virage
    Dec 2005
    Crows Nest, Queensland
    188
    Well it sure doesn't look like a DS injection engine, not that they had one in 1964. 2500 GTi Turbo it would seem upon inspection. I shudder to think what it cost to put that under the bonnet. It probably goes a lot harder than the original, but does it really add to the character of the car which I think is much more at home as a comfortable cruiser, not a sports car wannabe ??
    Robin
    Coffs Harbour, NSW, Australia
    624
    Sure is interesting under the bonnet. Is it a CX2500 Turbo motor with aftermarket injection ? Great finish detail ! Could be a bit of a handful without the CX suspension ?
    8,236
    Quote Originally Posted by citroenut View Post
    Hmmm, I thought the CX motor turned in the opposite direction = 5 reverse gears. . . So could this be a CX Turbo head on a 21/23 D motor?
    08 C5 X7 HDi very Noir
    16,623
    I have seen a blue DS23 with that treatment before. Nowhere near as shiny and clean as that. So it will be a CX2500 GTi Turbo motor with a different camshaft so it can run backwards. The CX has a bastard flywheel count, so given the coil packs, this one will have either a camshaft trigger wheel or crank trigger wheel out the back of the cam chain cover ( I have seen that a couple of times in pictures). Now with a well tuned after market modern injection system. ... with a knock sensor .... That motor is going to be pumping out way over 200hp. That little DS radiator isn't going to have a snowmans chance in hell of cooling it.
    The other conversion I have seen pictures of would have worked. They layed down the CX turbo radiator with it's big fans at an angle across the nose of the car (where the spare tire should be). That would have worked perfectly! My ID19's running one up with 68hp ( 60years ago ) are borderline as the mercury hits 40degrees.... that with probably 250hp that thing is going to expire in a cloud of steam 6 blocks from your house!
    I'm wondering what my ID19s would be like with 200->250hp .... And my imagination just isnt' good enough. The back suspension would live on the bottom bumpstops, and the front suspension would be nailed to the top bump stops each time you touched the loud pedal
    Jun 2015
    Narrabri, NSW
    1,019
    So. It is a massively complex and expensive solution to a problem that really never existed in the first place. All they really needed to do was slot in a good DS23 EFI motor and be happy with it being a fast cruiser. As Shane says, it would never be able to get all that turbo power to the road anyway. Some people just have way too much money..
    But it still looks lovely......
    Cheers, Peter J
    : 1976 16TS
    Apr 2016
    Bedford, UK
    808
    Somoene here in the UK was pointing it that it doesn't have the trade-mark boomerang rear indicators. I'm assuming that, as a genuine Chapron, it would have had - unless it was specifically commissioned back in 64 for the (American ?) market.
    I still don't like the look of the Decaps, but that mid-period nose suits it better that the 'cats eye' version.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    16,623
    I reckon it's absolutely spectacular.... I'd love to have a drive in it! I reckon the DS chassis would get the power to the ground quite well
    Nov 2001
    1,640
    So, I'm guessing I shouldn't have paid $20 to have my beloved 1975 2 litre manual DSpecial removed about fifteen years ago, then? They seem to have gone up a bit since then!
    Lets hope Jon Faine still has the tow-bar at least!
    Rod's Home Page
    Rod's car page
    Oct 2011
    Toowoomba
    650
    I don't think it would have 2500 pistons - the gudgeon pin offset is wrong for the opposite rotation. If it does it will crack the pistons pretty quickly.
    Jun 2012
    north fitzroy, victoria
    191
    Good to hear from you after so many years Rod
    you can come around and collect that tow bar any time, I trip over it at least once a month
    Jun 2012
    191
    in fact i called it the toe bar last time i stumbled over it
    Ici.
    2,624
    I'd much rather open the bonnet on that car and see the original motor. You would expect the car would be hell of alot of fun to drive though with a somewhat different attitude.
    Still it looks beautiful, but where are the rear indicators? Odd.
    16,623
    Quote Originally Posted by Bruce Llewellyn View Post
    It will be a CX Turbo engine re-cammed to spin the "wrong" way
    Feb 2012
    Ongar / England
    864
    Hello, this is how Peacock Engineering do CX thing
    http://www.citroen-dsm.co.uk/index.php/va-voom
