DSpecial: sulphur smell
Results 1 to 17 of 17
Like Tree10Likes
  • 1 Post By ajaxvte
  • 3 Post By pottsy
  • 1 Post By dee see
  • 2 Post By Ken W
  • 2 Post By pottsy
  • 1 Post By pottsy
Thread: DSpecial: sulphur smell
    Aug 2011
    407
    Default DSpecial: sulphur smell
    Excuse my ignorance, but can anybody advise on a noticeable sulphur smell that has developed in my DSpecial.
    At first I thought it might be drawing in exhaust from other cars. Then I thought it might be a bad batch of petrol. But no.
    A quick internet search tells me it is either the catalytic converter or possible fuel pressure regulator (and suggestion to replace fuel filter). Or possibly the battery (although I see no obvious buildup or problem there).
    Is there anything specific to D model Citroen that I should be aware of before investigating further?
    AM
    gsowner84 likes this.
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,024
    Only time I've copped such a smell in a older car was in a Mini when the voltage regulator had discombobulated causing the battery to overcharge dramatically. The battery being overcharged is about the only cause I can imagine in a DS that would cause such a pong.
    What happens is that the sulphuric acid within the battery gets so hot (may even boil) and emits gas, with an obvious sulphurous aroma.
    May I suggest you check battery voltages and charging etc, as a cooked battery is not a lovesome thing!
    Cheers, and keep us posted, Pottsy.
    GreenBlood, gsowner84 and Dano like this.
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's)
    1974 D Special Manual Sedan ("Moby Dick")
    2006 C5 HDI Wagon Auto ("Mephistopheles")
    1982 2CV6 ("Gaston") Seasoned traveller
    1975 GS Pallas ("GiSelle") Next project
    Oct 2018
    au
    49
    What he said/\/\ battery boiling
    Melbourne, Australia
    278
    Hi Ajaxvte
    I had this issue a few months ago. The alternator is overcharging the battery, causing the battery to leak.
    My mechanic advised me to get a new alternator and voltage regulator.
    Regards Syd
    1974 Citroen D Special (Blanc Meije)
    1989 Citroen 2CV 6 Dolly (Plum & Custard)
    Previously owned Frenchies -
    1976 Citroen GS 1220
    1997 Peugeot 306 XSi
    1995 Citroen XM Series II V6 (Vert Vega)
    Feb 2002
    Coolum Beach
    1,918
    Quote Originally Posted by ajaxvte View Post
    AM
    No catalyctic converter or fuel pressure regulator on a DSpecial,
    Leaves you -as the replies above show - with battery problem!
    DS Un jour, DS toujours !
    DS23 IE Pallas Automatique
    C5 X7 163 Exclusive
    C3 II 2010
    600
    I had this problem a few years ago when the battery was being charged at around 15v
    It also blew a few light bulbs
    Get a voltmeter and check voltage with engine running around 2000 rpm
    Should read about 13.5 max
    Aug 2011
    407
    Quote Originally Posted by harrisson_citroen View Post
    I had figured as much! Upon closer inspection, there is evidence of build-up - not much though - from leaking fluid on the clamps holding the battery in place. I won’t get to the car this month so will test the charges etc when I get back.
    1,024
    Can I suggest that until you can get to it that you leave the battery disconnected, just in case there are deep seated issues with your regulator.
    Better safe than incinerated!
    Cheers, Pottsy.
    Buvito Ergo Sum!
    The Fleet:
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    You should also neutralise the acid with some bicarb soda.
    GreenBlood and Dano like this.
    8,185
    Icon3
    Quote Originally Posted by Ken W View Post
    A very important tip. . . otherwise you'll be rewiring and replacing corroded contacts/connectors - don't ask me how I know
    I ended up scrapping the OE regulator and alternator and upgrading to a composite alternator!
    08 C5 X7 HDi very Noir
    Jun 2015
    Ashburton
    198
    I did the same with a composite unit - looks the same just no ancient regulator to worry about
    1,024
    One of the first upgrades I installed back in 2005. Still going strong.
    Bosch (aust) 85 amp with easily replaceable and removable integrated regulator.
    Fitted it to the Ducellier mount and Robert's yer father's brother.
    Cheers, Pottsy.
    Attached Thumbnails Attached Thumbnails DSpecial: sulphur smell-2-bosch-ducellier-mount.jpg   DSpecial: sulphur smell-1-ducellier-ducellier-mount.jpg
    GreenBlood and gsowner84 like this.
    Buvito Ergo Sum!
    The Fleet:
    Aug 2011
    407
    Many thanks all. Yes battery is disconnected and acid/powder build-up has been neutralised.
    Aug 2011
    407
    Finally got to the car after a couple of months today. Mulitimeter reads high 12s at idle and up to 14.5v at revs. Is this enough to cook the battery (predictably, driving the car today produced no sulphur smells...).
    Aug 2011
    407
    Went back to the drawing board this morning and tested the voltage at higher revs - 3-3,500 revs. The output was much higher, at 16-18v. So problem confirmed, I guess. The existing regulator was a repro one I bought off Roger Parker a few years ago. This time looks like I should now just go down the replacement alternator with built in regulator route. The Citroen websites (Citroen classics, l’Atelier524, der franzose etc) are very expensive, with exorbitant freight. Can I please seek advice on where and how to source one locally...
    1,024
    At the end of the day, an alternator is a fairly standard item anywhere. You could try most of the larger Auto Parts places, perhaps Burson's. Maybe an auto electrician.
    I sourced my Bosch unit from a local parts supplier (now retired) who had a suitable unit on the shelf. If you take the old one with you they should be able to come up with something that will fit.
    I'll admit I had to do a bit of juggling to get it on the Ducellier mount but time has shown it to be worth the effort.
    Of course, if you're seeking something indistinguishable from a factory fitting (never been a priority for me) you could maybe get the existing one and regulator overhauled by an Auto Electrician.
    Cheers, and bonne chance, Pottsy.
    Buvito Ergo Sum!
    The Fleet:
    Dec 2010
    Wagga Wagga
    347
    A Holden Commobore alternator replaced our D Special's original Paris -Rhone. We also replaced the original mechanical voltage regulator with an electronic one. Not expensive.
