Xantia Discs and Pads
Results 1 to 9 of 9
    Sydney, Australia
    20
    Default Xantia Discs and Pads
    Hi All,
    I asked this over at CCA as well, but thought I would give it a while here too:
    I need to replace the full set of discs and pads on my family's Xantia Turbo Diesel. Does anyone have some recommendations on the best/cheapest place to purchase from?
    Lucien.
    2000+ Brad's Avatar
    2,404
    DBA make both smooth and slotted for your car. It's part number 274, 266mm diameter. The slotted ones are $137.21 ea from Autospeed
    From memory the non slotted are about $100 ea.
    These will last much longer than the OEM ones, however apparently in smooth format are not as 'grippy'. I believe the smooth would be around half the cost of the OEM ones too.
    Sydney, Australia
    20
    Quote Originally Posted by Brad
    *SNIP*
    Thanks Brad, great info. Anyone (else) had experience with the DBAs?
    LW.
    7,460
    Quote Originally Posted by lwells
    LW.
    I'm currently using the OEM Xantia rotors on my 205 race car. They're only $90 ea from AutoFrance. They seem OK to me. I've slotted them though before fitting.
    Sydney, Australia
    20
    Front, rears, or both?
    Lucien.
    7,460
    Lucien.
    Front.
    Sydney, Australia
    20
    Front.
    I will give AutoFrance a call tomorrow (if they are open). Even if I go with the DBA rotors, they only produce fronts so I would need a set of backs from somewhere else.
    Lucien.
    2000+ Brad's Avatar
    2,404
    Wow, didn't know they were that cheap. I'm assuming these would be the same as those on the Mi16's and S16's?
    16,424
    Hmm,
    I have a feeling the rotors are only about 12pounds each in the UK. If your not in a hurry it could be much cheaper to post some out
