Random idle misfiring and strange fuel trims. DS3 THP
Results 1 to 19 of 19
Like Tree8Likes
  • 1 Post By seasink
  • 1 Post By David S
  • 1 Post By X8R
  • 1 Post By seasink
  • 1 Post By dmccurtayne
  • 2 Post By X8R
  • 1 Post By seasink
Thread: Random idle misfiring and strange fuel trims. DS3 THP
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Default Random idle misfiring and strange fuel trims. DS3 THP
    Hi all
    I recently bought a 2011 built Citroen DS3 1.6 THP that had a myriad of issues, now mostly solved. An intermitent misfire at idle (cold and warm) still remains as well as some mid-range hesitation and lack of torque. It feels like it is retarding ignition or pinging. Strangely, there are no fault codes or check engine light on.
    Originally with 86,000 km it was running very rough. I got following operations done at my local BMW mini specialist in Burwood, Melbourne which made the car run a lot better:
    - Walnut blast intake valves ($450)
    - Changed one bad coil
    - Replaced all 4 spark plugs
    At 89,000 km, Citroen changed the timing chain and tensioner and advised the intake valves were "very dirty" and quoted the exorbitant sum of $2000(!) to clean them which I didn't end up doing. Can the valves be so dirty only after 5,000 km of a walnut blast? I do use Castrol EDGE 5W-40 A3/B4 the manual calls for. I did a complete oil flush and oil filter change at 90,000 km myself.
    - My crappy OBD reader can't count the misfires but I can definitely hear my exhaust puffing randomly and shaking at idle. Torque at mid range seems lacking. Surges and hesitates at wide open throttle (WOT) below 4,000 rpm
    - I checked the fuel pressure and I get a very constant 5000 kPa at idle to ~11000 kPa at WOT so I don't think my HPFP has failed yet. Cold and warm values are the same even when misfiring.
    - My short term fuel trims do look very strange. At idle, the trim is mainly constant around 0% change even when shaking. At light load the fuel trim fluctuates up to +15% while at WOT can go up to -15%. To be honest, these values don't make much sense to me. Unfortunately, my OBD reader for some reason can't read the long term fuel trims which might tell more.
    - I checked for evident vacuum leaks or broken hoses but I can't see any
    - I see there's quite a lot of vacuum inside the valve cover. I can't even take the oil filler cap off at idle
    - The brittle PCV hose on the driver side seems in good condition and if disconnected, the idle gets even worse as it should. It is very oily inside. My car burns around 1 litre every 5000 km
    - The passenger side PCV rubber hose going to the turbo is very clean and there's no oil residue at all. Is looks like it might be blocked or stuck closed?
    Due to the intermitent nature of the bad idle and hesitations under load, my guesses are:
    - Bad O2 sensor?
    - Spark plug gap too big? I am running the stock 0,75mm
    - PCV valves stuck open / closed?
    - Am I missing anything? How can I diagnose the above?
    Thanks in advance, I've spent a few weeks researching in this forum as well as all the R56 mini forums out there. This car is driving me crazy, it should be more powerful than it is and the intermittent rough idling is annoying. Unfortunately, the mechanics I have visited so far have not been able to make it run right. I iz sad.
    Is there anyone in Melbourne with a THP engine willing to catch up over over a beer or two?
    9,239
    The behaviour without error codes suggests carboned inlet valves/ports, or plugs or coils. All of them done, though how did someone say the valves needed work without dropping the manifold?
    A regular miss should produce an error, and swapping a bad coil should make the code number swap.
    Trims might be a timing problem. Oily could be leaking at the turbo seals.
    5-40 is a bit thickish. Current advice is C2 0-30W, that is the same as the PSA diesels. This is to minimise ashing the ports.
    It needs more thought, by me at least, but some codes would help. DS3s should accelerate very smartly and smoothly.
    antonio likes this.
    10,041
    Firstly, have you had the airbag recall performed?
    Is the battery in good shape? The car isn't tolerant of a weak battery. Load test it.
    Check with a dealer for any outstanding service campaigns. There are a couple that may be relevant to your car, such as the oil solenoid and coolant temp sensor.
    From what you mention, it may want an engine/cam cover as that has two diaphragms in it for the PCV and they do fail. The larger one is under a round cover and you can buy a replacement, but that won't help you if the smaller diaphragm inside has failed too.
    Did you read this? Peugeot 308 EP6 1.6 THP revised valve cover design?
    PSA now suggest using the low ash oil they specify for the HDi particle filter cars. This is meant to reduce the valve deposits. It's likely a good idea to use a cylinder head cleaner like the Subaru foaming product with each oil change.
    Plugs won't make it much past 40K. Coil faults are sometimes phantom and the suggestion now is to swap them around and see if the fault moves the coil before concluding a coil is faulty.
    antonio likes this.
    Jul 2013
    Newcastle/ central coast
    2,222
    If itís hard to pull the oil cap off while running replace the rocker cover donít bother with the kits by the time you get it apart and find itís all stuffed you are better off doing it all also they donít last long at all
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    I am not sure the dealership had a look at the actual ports to see the valves. I really doubt they were bad after a walnut blast (5,000km ago and some Liqui Moly intake decarb done 1,000 km before. I did another extra spray decarb before my last oil change.
    The dealership changed the timing chain and the behaviour was exactly the same so I don't expect to be a timing issue.
    Thanks for the advice on the oil. I see now everyone is running low-mid SAPS and thinner oil. Is there any particular brand you guys recommend? I thought my behaviour could also be due to low speed preignition (LSPI) caused by the oil.
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Hi David
    Yes, airbag recalled as well as all the service campaigns, I called a couple of weeks ago to make sure all was done. Cheers.
    I also changed the battery recently, the car was running like crap with an old one!
    I also suspect the cam cover and it's PCV's may have failed. The amount of vacuum in is tremendous. The car is adding fuel +15 to 20% (STFT) at low loads as there was a vacuum leak. At WOT it takes about -10% fuel off. Thanks for the thread, I'll have a proper read on lunch time.
    I may buy 4 new coils just to be on the safe side and get some C2 oil for the next oil change.
    Thanks again for the input, you guys are legends!
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Quote Originally Posted by dmccurtayne View Post
    If it’s hard to pull the oil cap off while running replace the rocker cover don’t bother with the kits by the time you get it apart and find it’s all stuffed you are better off doing it all also they don’t last long at all
    Definitely, I think this is the main culprit.
    https://www.ebay.com.au/itm/Citroen-...PyOK:rk:5:pf:0
    For $190, I think it should be an easy fix.
    Thanks a lot for your opinion!
    antonio likes this.
    9,239
    Citroen always recommend Total Quartz Ineo ECS 0-30w (when the car was new it was 5-30W, but they have revised the recommendation)
    In some states it is hard to get, but in Vic the Total distributors would sell you 3 off x 5L containers per carton at a sensible price. Slightly more ash content, but available everywhere is Penrite Enviro+ C2
    I suspect the dealership took a stab at diagnosis on the basis of the driving behaviour as I did. The vacuum holding the cap is a bit off - dmmccurtayne knows these engines.
    My DS3 got its valves and ports cleaned with solvent and skinny scrapers using a mirror to see by. It was an all day job. PSA dealers stock the rather expensive solvent. I am very fond of the little car.
    antonio likes this.
    9,239
    Re valve cover - note differences in the referred thread. Get seals as well (inc at plugs).
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Thanks for the recommendations!
    *** UPDATE ***
    I finally got the OBD working well and it is showing some misfires in cylinder 1 and 3. I swapped the coils 1 to 2 and 3 to 4. And the misfires did not travel with the coils. I suspect the misfires are not coil related then and may be carbon buildup or compression leak?
    Maybe the next job will be to remove spark plugs and recheck gaps and condition.
    If everything else seems right, I'll continue with some compression or leak tests. It not sure now if a bad valve cover/pcv can cause this cyl 1 and 3 misfire only. Cil 2 and 4 show 0 misfires at all.
    Strangely, the misfires are not constant, sometimes they don't happen at all during a drive cycle...
    Jul 2013
    2,222
    If youíve got incorrect vacuum then your fuel trims will compensate up to the limit then you get random misfires but in saying your getting 1 and 3 that smells like a fuel pump to me but the rocker cover still will need doing lesser of two evils
    antonio likes this.
    Garage C5 X7 4008
    Jan 2015
    159
    Hi I have read your thread if you have misfire faults on 2 cylinders I would say itís the hp pump, you also mentioned that the car can misfire from cold which is another sign the pump is failing. As for the rocker cover if the Pcv has failed they often make I whistling sound at idle.
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Hi dmccurtaine and turbo pug
    The HPFP could be one of the suspects too but I am getting constant pressure at idle and spikes and stays up consistently under boost. Excuse my ignorance but does the fuel pump have different outlets for different cylinders? Isn't there a common rail? I'd guess if it was a HPFP issue, all cylinders would randomly misfire, not only 1 and 3?
    I leave the screenshots of the misfires in cyl 1 and 3
    Plus the -strange to me- fuel trims under idle (left of the graph) and at 2500 rpm no load (right of the graph)
    Don't you think the ECU is trying to compensate too much? I'd guess I have a vacuum leak or PCV valves don't work properly but I don't hear any hissing noises.
    Thanks for your comments!
    Jul 2013
    2,222
    The have two pistons that surge in volume around injection time thins is why the pumps have this problem , if that makes sense.
    The new ep6 pumps are just single piston but not interchangeable
    Garage C5 X7 4008
    Jul 2013
    2,222
    Do you have any live fuel trim data at idle and 2000rpm
    Garage C5 X7 4008
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Hi dmccurtayne, yes, it's the last photo in y last post. Screenshot_20181222-155616_inCarDoc Pro.jpg The left side of the graph is at idle, and the right side is at 2500 rpm (no load). I find the ecu is trying to overcompensate too much. What's your opinion?
    Oscar
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    ***UPDATE***
    Hi all
    The car was still throwing the random misfires and superknock codes, so I got hands on and eventually fixed it. It was carbon build up.
    I disassembled the intake manifold which was quite a pain in the backside by itself. There are some bolts difficult to reach.
    I used my phone and a boroscope camera to see the valves and definitely there was copious amount of carbon build up, especially in Cyl 1 and 3 (as the codes pointed out).
    I used carby cleaner to spray and soak the back of the valves for a few hours. I scrapped them with a plastic prying too and came out 95% clean. I sucked out all the dissolved crud and did an oil change.
    The car runs absolutely beautiful now and has al the power I expected since the beginning. Fuel consumption has gone down from 7.5 to 6 l/100km
    Conclusions:
    - I am not sure the walnut blast was done right initially as it should have fixed the issue. There was a lot of crud left
    - The "upper engine cleaner" spraying through the throttle body did not cut it
    - There's no need to take the cylinder head off like many shops want to do and charge $2000 for it
    I went to several mechanics and any of them fixed the issue. I guess if you want to get it done right, you have to do it yourself o pay through the nose.
    I hope this helps you in case you find yourselves in the same situation.
    Trading Estate and seasink like this.
    9,239
    As I suspected, it was just like my car. I used the rather expensive Peugeot/Citroen solvent and skinny metal scrapers.
    The fixings and fittings at the rear you really need to know about beforehand, because it's all by feel. In a DS3 it's a very confined space. For that reason I think people should use an experienced PSA mechanic who has done it before, or else get a diagram from Citroen.
    I didn't think of a phone, but used a mirror and torch. Otherwise it sounds like the same job.
    Upper engine cleaner might slow it, but cannot clean it. De-crudding certainly makes a difference.
    You'll get less burnt-on ash in future if you change to low ash C2 grade oil, as for the HDI engines.
    X8R likes this.
    X8R
    X8R is offline
    Jul 2018
    Burwood, Melbourne
    13
    Correct, the new oil I used is a Penrite C2, 0W-30 which complies with PSA specifications.
    Oscar
