23 EFI cooling
Results 1 to 19 of 19
  • 1 Post By brian woodcock
Thread: 23 EFI cooling
    Kapunda
    487
    Default 23 EFI cooling
    I have recently removed the standard Aux air device and replaced it with something much simpler, but that's another story. I,m interested to find out if blocking off the water outlet at the rear of the water pump will have any deleterious effect.
    Woody
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,030
    Tell us the story about what you replaced the aux air valve with on the DS EFI ? I have to do something similar on the SM EFI.
    Cheers, Ken
    Feb 2002
    Coolum Beach
    2,027
    Yes, you either said too much , or not enough. We want to know the WHOLE story.
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    554
    Quote Originally Posted by brian woodcock View Post
    Woody
    I dont think it will matter if you block off the water hoses.
    But more importantly is what you replaced the Aux air with , I have the same problem with my DS23 EFi
    on a completely different subject do you know where the temp sender is located as my temp gauge does not work.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Kapunda
    487
    As for the Aux air valve, I got a 3/8 ball valve from Bunnings which is located discretly under the dash, this is connected to the inlet manifold with 3/8 tubing. When fully open is causes the cold engine to idle at about 1000rpm. It produces a gentle hissing sound which is a reminder.
    Regarding the temp sender, sometimes on the water pump housing, sometimes in the cylinder head towards the rear between induction pipes.
    jaahn likes this.
    North Brisbane
    2,030
    Sounds like a manual controller for idle speed Woody.
    I got a hint from John Walton at DS Motors and that is to use a BX TRI/TZI idle speed controller. You plumb it into the auxiliary air line and connect it electrically between 12 volt and chassis. When cold the orifice is open and allows extra air into the inlet manifold. As the internal resistor heats up the rotating mechanism inside, the orifice gently closes off at about the same time constant as the engine warms up and needs less air. I think it seals better with air flow through in the direction so that atmospheric pressure pushes against the rotating disc against the fixed disc.
    If anyone else tries this, let us know how it goes.
    Cheers Ken
    Kapunda
    487
    Ken ,I formerly used one like that off a Nissan Skyline until it packed up.
    Woody
    Mar 2005
    913
    My DS23 injection had its temperature sender unit attached to the additional air control, buried way down near the extra oil cooler duct on the left side of the engine sump. maybe the replacement with a non genuine item means the original placement is just no longer available. It was a B/W automatic so who knows if that makes a difference or whether it is the usual batch by batch production differences at play.
    Kapunda
    487
    I believe that item on the Aux air valve is a temp switch, presumably for the red light. I have never had a D with an original temp gauge so I am in the dark there. The item towards the rear of the head with 2 wires is the thermotime switch.
    Jan 2012
    211
    Depending on model, year and day the car was made the switch for the dashboard light is either on the aux air valve or screwed into the water pump housing.
    OP 521.4 in manual 814 goes through fitting a temp gauge and sender to the water pump housing
    Mar 2005
    913
    Nope !!! I connected a temp sender that was attached to the aux air control to a temp gauge, both supplied as new genuine parts....in period when such things were available.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    348
    I took my AAV and hoses off completely, connected a new water hose from the back of the pump to the alloy connector thatís bolted to the side of the cylinder head and fitted a plastic cap to block the hole in the inlet manifold where the air hose usually fits. Have been running like that for 2 years, without problems. Itís just a case of using the throttle pedal a bit to stop it from stalling when the engineís cold for the first minute, or preferably just get moving and once youíve gone up through the gears once or twice thereís no chance itíll stall.
    I donít drive it in really cold weather or have to join queuing traffic straight away when not having an AAV might be a bit more of a problem. Iíve found it so little hassle that I wonít be going back to fitting one, even if someone gave me one for free that worked properly 🙂
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Jan 2012
    211
    The AAV is almost impossible to keep in working order on cars that arenít regularly driven. I ended up bypassing it completely. Car starts just fine on 5deg mornings with a bit of throttle.
    Itís handy to keep it plumbed in if you want somewhere for a temp sender and a switch for the dash light. Iíd be loathed to only have the temp gauge sender.
    Kapunda
    487
    This is all very interesting stuff but how about dealing with my original question!
    Woody
    Jan 2012
    211
    Instead of blocking off the outlet, run a hose down to where it joins the lower radiator hose
    Mar 2017
    Grafton
    142
    Quote Originally Posted by faulksy View Post
    I agree , a bypass hose is better than plugs. I am in the process of fitting a temp guage to my 23 efi. I got a new sender for the auxillary air supply unit but to sender doesn't work! Its open circuit when hot and cold. Citro Services have promised a replacement.
    Sent from my LG-K520 using aussiefrogs mobile app
    Kapunda
    487
    But note that the outlet from the rear side of the water pump and the lower Rad hose are both on the suction side of the pump!!
    A bypass is provided by a drilling in the Pump housing.
    Woody
    North Brisbane
    2,030
    Woody,
    I would plug it so you get more coolant flow through the engine. If the bypass is unrestricted, it will take a lot of the flow from the pump.
    Cheers, Ken
    Jan 2012
    211
    The aav doesnít really provide much of a restriction so shouldnít be a problem with bypassing it. The other option is to simply leave it plumbed in without the air hoses
