Lhm leak- assistance required ds23
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By citroenthusiast
Thread: Lhm leak- assistance required ds23
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    368
    Default Lhm leak- assistance required ds23
    can anyone advise as to how you remove/replace the return rubber elbow that carries the low pressure return pipes on the drivers side of the car. it goes through an aperture adjacent to the jacking point and below the brake distribution hydraulic junction block.
    any written and diagrammatic information will be appreciated.
    thankyou
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,864
    You must be the first person to have one fail.
    Hopefully someone will reply before you have to work it out for yourself.
    Cheers, Ken
    Apr 2014
    Phoenix, Arizona USA
    637
    RHD driver's side or LHD driver's side? On the right side there is a rubber elbow, which looks something like a tobacco pipe with one large tube at one end and two smaller tubes at the other end. To get at it you have to remove the suspension cover and the rocker covers, then working from the rocker area, you remove an M5 screw, which holds a bracket supporting the return pipe and the fuel pipe where it passes through the solid frame section. Once this is loosened, you can move the tubing far enough forward to get to the hose clamp holding the elbow to the return pipe.
    JohnW and mberry like this.
    John T.
    54 TAV Legere; 61DS19 LHM BVH (son's); 71DS21 BVH; 73SM 3.0; 73SM EFI (Megasquirt); 73SM 3.0 (other son's)
