D Starter Motor?
  • 1 Post By Budge
Thread: D Starter Motor?
    Kapunda
    459
    Default D Starter Motor?
    On tidying the shed I have found a SM which i dont regognise. It will fit a D except for its large pinion which has 10T.It is much fatter than the usual d SM. Part No is Duc 6182A Does anyone know what its off. It is looking for a new home.
    Woody
    Apr 2016
    Bedford, UK
    723
    You asked this before. It's from a DS21. It's a beefier starter used on the DS21 - as opposed to the Ds 19 or Ds 20. the 6182A variant is from circa 68 to 69. I rebuilt one earlier this year.
    GreenBlood likes this.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    10,862
    I was laughing at anyone not recognising an SM...
    Sorry, couldn't resist.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Apr 2014
    Phoenix, Arizona USA
    681
    Early 5 main bearing DS starter motors had 10 teeth. Around 1970 the flywheel was changed and the starter motor revised to have 9 teeth. The ID retained the 10 tooth starter for a while after that.
    Here is a photo of the two types of starters. The 10-tooth starter is easily identified by the much larger pinion.
    John T.
