David Williams
Results 1 to 11 of 11
  • 1 Post By David Williams
Thread: David Williams
    Jun 2017
    Queensland
    19
    Default David Williams
    Hello All,
    Anyone have an idea where I can buy/steal /beg a hand brake cable for a 1974 DS19. Mine broke!!
    badabec likes this.
    Aug 2011
    406
    Try Denton Christie in Sydney or the UK-based Citroen Classics website. They have them at GBP68.85. Plus, of course, postage. So you’ll be looking at not far short of a couple of hundred dollars....
    Faulconbridge
    2,317
    Sounds like a one-off;no such car as a 1974DS19.
    Apr 2016
    Bedford, UK
    651
    I think the conclusion reached was that this was a 1974 model year D Special - possibly manufactured in late 73 and so wrongly registered as a 73.
    The D Super came from the ID20, whereas the ID 19 lived on in the form of the D Special (under-bonnet plates for Specials still stated 'ID19'). So, technically, it could be regarded as a '19' derivative - but it will confuse people.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Ici.
    2,479
    Hey Budge my DSpecial has DS then serie FD on it. which makes it a DS and not an ID! 74 model. : )
    some people hate that fact.
    Newcastle
    2,557
    Hi David
    It is possible to make up a new cable using marine SS rigging wire and marine fittings swaged on with correct tools. I am not familiar with your cable so take this as general information. They have a selection of end fitting which may be able to be used.
    Recently I made up a clutch cable for my son-n-laws Mitsibishi van as the original is unobtainable now. The local marine dealer will have the stuff. You reuse the outer and grease it with some molly grease. Cost us about $8 I think but only had an eye each end. I have a crimper but they usually will crimp them for you as they custom make sailing boat rigging on the spot. Just be careful on the length and double check it.
    Jaahn
    Apr 2013
    Essendon
    618
    Hi David
    Jaahn
    Agree. You can make your own. However, whilst not as cheap as making your own Flexdrive will make one up to your specifications / sample.
    If nothing similar in Qld to Flexdrive , may I suggest you ring them and send it down to them.
    I got them to make my accelerator cable for the automatic D.
    9,615
    See: https://www.franzose.de/en/Citroen-D...andbremsseile/
    Not exactly expensive, but check the part numbers to get the right one for the car in question.
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    748
    Hi David
    Jaahn
    Having a hand brake cable on my DS21 break it was taken to a firm that made cables. Before you take it from the store check it against the original! We didn't and found it was a fraction TOO short and couldn't be connected!
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    Jun 2017
    Queensland
    19
    Default DS hand brake cable
    Quote Originally Posted by David Williams View Post
    Hello All,
    Thank you to all members who replied to my post regarding sourcing a new parking brake cable for my D.
    I found a guy in Beerwah Qld. who makes all sorts of cables. He will be able to sort me I'm sure.
    Thanks once again.
    9,615
    While you are there ... check the state of the handbrake caliper pivots. In old age, the bush wears and the arms drop to the point the spring starts to rub and wear a groove into the edge of the disc. I don't think the correct bush can be bought, so fitting bronze bushes and reaming them to suit may be required to fix that.
