Slight surging feel ’68 Safari
Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By GreenBlood
Thread: Slight surging feel ’68 Safari
    Jul 2004
    Castlemaine Area
    573
    Default Slight surging feel ’68 Safari
    Thinking of taking our newly registered ’68 ID19F Safari to Malmsbury “Show and Shine” tomorrow, Saturday 12th Oct.
    Because our car is only now seriously up and running I don’t know the car well.
    There is, what seems a slight surging under load. I thought I was only imagining it but just now I went up a slight grade in 1st and thought I definitely felt it. A slight rer-rer-rer feel. It is similar when there is a bulge in a tyre. At speed it is only very slightly there.
    I have checked tyres but as I was going up the slight hill just now it definitely felt more than a tyre bulge.
    It happens at about the same rate as when you see the ignition light pulsating in some cars. The ignition light does not waver in this car.
    I just pushed the car in neutral on smooth concrete and - - silent.
    I have checked that the drive shafts are loose but no.
    Any ideas, John
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,958
    Have you checked basic things such as idle mixture adjustment? Air leaks in vacuum lines, induction system, etc. I assume that the advance curves for the distributor are correct?
    I assume that points and condenser are good?
    Cheers Gerry
    8,103
    Engine mounts. . .
    UFO and gerrypro like this.
    08 C5 X7 HDi very Noir
    Jul 2004
    Castlemaine Area
    573
    I'll check engine mounts.
    It has a 123 electronic ignition. I'll look into the carbi and vacuum leaks. It went well to Malmsbury car show today and tomorrow morning I'll take it to Ballarat Cars & coffee.
    I had the car jacked up with the wheels off the ground. Drew quite a crowd.
    John
    Attached Thumbnails Attached Thumbnails -malmsbury-1-2018.jpg   -malmsbury-2-2018.jpg
    2,958
    Perhaps all it needs is a few good long runs to blow the cobwebs out!
    Cheers Gerry
    Jul 2004
    Castlemaine Area
    573
    Yes Gerry, left here at about 1/4 to 6 to get to the Ballarat Cars & Coffee by 6.30 or so. Already a few cars there but got a free coffee as I was part of the 1st 25 cars or so. It was a blast to drive the wagon at dawn. I was thinking as I drove how clever the switch from parkers to low beam is as I put low beam on when cars came closer on these country roads after the sun had kind of come up. It never ceases to amaze me how good these D's are.
    What I like about the cars & coffees is that there is no big fanfare, no big money - - just the passion for cars and being around them.
    I probably went through the motions of "jacking" the car up - - then on props (Safaris have for two ) and letting the wheels lift off - - probably 4 - 6 times sometimes letting kids work the height lever - - - never failing to draw a crowd. There was a lovely original '52 or so twin spinner Ford looking like it just came off the boat from the US. Many older cars so a good time. Then had a hot dog at the Dean dog trials where there were steam traction engines - - - big, big and caught up with with a friend with a traction and gave him a drive of the wagon - - just to let him feel what he's missing out on.
    The car is a dream, John
    2,958
    That traction is now in pieces and will end up driving very, very well. Then it will be a toss up as to which is better to drive!
    Cheers Gerry
    9,310
    On the 123 distributor, there is a rotary dip switch under a screw plug and you need to select the correct curve for the car. The one I fitted to a 23IE recently came set to 0, so needed to be set correctly. Was this set correctly?
    Even a warped or unevenly surfaced brake disc, say after a layup left a rusty spot, could give you a shudder.
    Jul 2004
    Castlemaine Area
    573
    I've copied this down for future reference. John and Lance at DS Motors were like gods so not that prone to mistakes but I'll definitely keep this in mind.
    Thanks, John
    16,168
    Quote Originally Posted by gilberthenry View Post
    I'm a real fan of the cars and coffee.... Generally its only the real car nuts that turn up to them ( all the people that love politics in clubs seem to avoid them). My only issue with the ballarat one is I never get to them. They are simply too early. Who wants to get up at 7:00am on a sunday morning. If they ran the things from 9:00am -> 11:00am they would be twice the size! Having said that, the ballarat one is already filling the carpark at Sovereign hill and overflowing into there overflow carpark down on main road That is how popular it is
