DS - CRC Rebuild Kit
Results 1 to 13 of 13
    Apr 2016
    Bedford, UK
    578
    Default DS - CRC Rebuild Kit
    Has anyone here used an after-market kit to rebuild the clutch re-engagement control (CRC) of a bvh DS?
    My car is a carb car. I bought a rebuild kit and in addition to four springs, a ball bearing and a gasket, it has six O rings:
    • Two big ones go on the caps that are held in place with spring clips/ 'C' clips
    • One medium sized one goes on the adjuster with the slotted end.
    • Two other medium ones are made into oval shapes and go on the flat plate sandwiched between the CRC and the hydraulic pipe.
    • But what about the sixth, small one?
    I looked on the internet for clues. Franzose sell a kit with three o rings - presumably first three listed above.
    Dirk Sassens sells a carb car kit with five o rings but a kit for injection cars with six?
    Have i got the right kit? Whats the difference between the kits for carb and i.e.? Is it the springs? The ball bearing?
    Does anyone know?
    Paul
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Jun 2011
    11
    Might be oring on main shaft but big job to fit
    Apr 2016
    Bedford, UK
    578
    Thanks. I did think about that but, as you say, that would not be an easy job. I also wondered whether it fitted on the nozzle of the LHM return pipe - but that has a copper washer
    Also, I'm struggling to see why Dirk Sassens would sell a ket for injected cars with six 'o' rings, whereas the carb car kit only has five? I'm wondering if that distinction is down to the alternative mounting point for a CRC on an injection car - but even then, the basic mechanics are the same? Maybe the relocation means a pipe has a join needing an 'O' ring?
    Ultimately, and whatever the reason, I'm wondering whether I have the injection car kit by mistake and, if so, is there any difference in the parts other than that 'O' ring - such as the springs and sizes of the other five 'O' rings?
    Jun 2011
    11
    Injection cars mounted by two studs , no oring
    Apr 2016
    Bedford, UK
    578
    Thanks - yes. so where DOESN'T the 'O' ring go?
    Jun 2011
    11
    Just checked , the shaft does have an oring on it
    skp
    skp is offline
    194
    As you say, they all function the same - just different mountings. I wouldn't worry about it. A spare!
    skp
    Apr 2016
    Bedford, UK
    578
    Quote Originally Posted by myourd View Post
    Thanks Myourd. Your post is very interesting news! So, where exactly does it fit please? Can you describe?
    Presumably it goes on the rotating shaft that is joined to the carb by the flector? But if so, which end of that shaft does it go (as both would be potential leak points) and how/ where is it fitted? presumably from inside the unit with the shaft removed?
    Jun 2011
    11
    Yes ,I removed the end cap and knocked the shaft out , thats as far as I went , will send a photo on Monday to show position of oring
    Apr 2016
    Bedford, UK
    578
    Yes please - interested in that photo. Also interested in that 'knocking' technique.
    1000+ Posts michaelr's Avatar
    1,394
    Is this the o ring you are looking for?
    Michael
    Member, Citroen Car Club NSW
    Apr 2016
    Bedford, UK
    578
    Yes! Thanks - that's really handy to know, but it will have to wait until next time as I have rebuilt the CRC now - unless I find that it leaks.......
    Handy photo. You can see the setting hole in the cam. What stops the cam rotating independently of the shaft? What keeps them together? Are the two parts splined, or is the a worm screw or something? Or is it a tight press fit?
    Thanks again
    Budge
    Apr 2016
    Bedford, UK
    578
    Michael - any chance of a couple more photos showing the area around the outside where the shaft fits and maybe the same from inside? I'm trying to get an idea of what bits come off and what bits stay on the unit when removing the shaft.
