1954 Traction interior light and steering wheel
Results 1 to 10 of 10
Like Tree7Likes
  • 3 Post By tractionfan
  • 2 Post By birks
  • 2 Post By gerrypro
Thread: 1954 Traction interior light and steering wheel
    Fellow Frogger! brycedunn's Avatar
    Jun 2012
    165
    Default 1954 Traction interior light and steering wheel
    hello everyone,
    Is there a trick to remove the steering wheel on a slough traction?
    I've removed the cover, the nut and washer, but I assume I need some kind of puller. Doesn't look like this wheel would work with a standard one you could get from supercheap or anything like that?
    Secondly, I would like to reconnect my interior light. I seem to be missing the base? Is this a standard lucas item I can get a new one from? Or does anyone have one they would be willing to sell? Is this even the right one for a 1954 Light 15?
    Thanks,
    Bryce
    1954 Light 15
    1970 DS21 BVH
    http://www.classicjalopy.com
    Fellow Frogger! tractionfan's Avatar
    280
    I usually plant my feet on the floor, get my muscles out and wrestle them off. One tip though if you use this method. Put the nut back on the shaft. If you don't you'll hit yourself on the nose with the wheel.
    hope I've helped.
    jaahn, forumnoreason and brycedunn like this.
    Tadpole birks's Avatar
    Sep 2015
    AU
    12
    Quote Originally Posted by brycedunn View Post
    hello everyone,
    Thanks,
    Bryce
    Hi, Brice if you grab the steering wheel on the outside near the wheel spokes in the horizontal position and push on one side whilst pulling on the other side sitting in the drivers seat and doing this
    alternatively, she'll let go of the tapered spline. Failing that, whilst pulling and at the same time giving the steering shaft
    a knock with a soft mallet it should come apart. Srew the nut on the shaft with two turns to go, so you don't injure yourself our your helper.
    Cheers Keith.
    Sent from my SM-N915G using Tapatalk
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,968
    That wheel is only on a taper and a woodruff key. There is no spline. Use a block of wood behind the centre boss and hit the block with a Mallet. The interior light is complete. The end plate is spring loaded and can be moved outwards to release the lens. The base then is screwed to the wooden roof rail through the head lining.
    BTW that is the wrong steering wheel for a car with round dials. The correct one is brown and attaches with a multi holed plate that allows almost infinite position adjustment so that the spokes can be positioned horizontally.
    Cheers Gerry
    Jun 2012
    165
    Quote Originally Posted by tractionfan View Post
    hope I've helped.
    Quote Originally Posted by birks View Post
    Cheers Keith.
    Thanks for the replies on the wheel. Its never been on straight since I got the car and it would be nice to have it straight. I'll give this a try in the next day or so.
    I wondered that as I had seen some different ones on cars for sale. From what I gather there were not many round dial cars made so the chances of finding a decent one are probably low.
    This is the underside of the light:
    I can't see how it attaches to the car.
    On the headlining, there is a hole where I can feel the wires (taped up with elec tape), but nothing to attach the light to.
    Thanks,
    Bryce
    1954 Light 15
    1970 DS21 BVH
    2,968
    Thanks,
    Bryce
    The wheel will not go back on straight with out some serious work on the steering rack. The trick is to have the entire rack out of the car and dismantle it completely except for the steering column and its bearings.
    The steering wheel needs to be loosely fitted to the column with the woodruff key in place.
    Then the rack gear is fitted with the wheel spokes quite off horizontal . This is a trail and error process. When you fit the rack and can obtain a measurement of 37mm +/-2 protrusion of the rack teeth past the end face of the steering column bearing housing ( end cap removed ), and the steering wheel spoke at the horizontal you then will have a horizontally orientated steering wheel. Paragraph 16 Operation 125 Page 81 of the Work Shop Manual.
    Of course then you will need to reassemble the rest of the rack.
    It looks like the back plate of the interior light is missing! ( As you originally suspected).
    Cheers Gerry
    Jun 2012
    165
    Thanks... Since the steering column looked splined I was hoping I could make it straight just by taking off the wheel and re-orienting it. Sounds like this is not the case. I did this on a Mercedes I had it was a 10 minute job.
    Bryce
    1954 Light 15
    1970 DS21 BVH
    2,968
    You do realise that if you fit the correct later model steering wheel then the process I outlined is not necessary. In this case the wheel adjustment is carried out with the steering boss!
    Cheers Gerry
    2,968
    There is another alternative but it means modifiying the steering wheel. First it is essential that the alignment is correct and that the track rods are equal in length ( very important for correct Ackerman principles to be maintained on left and right lock.
    Mark the end of the steering column the exact position of the key slot. Chalk or marker pen etc. The wheel needs to be loosely fitted without the woodruff key. Then transfer the mark made earlier to the wheel boss. Now by carefully filing cut a new key ay slot in the wheel boss. Finally refit the key and wheel in the new position.
    Cheers Gerry
    Jun 2012
    165
    I think I will keep an eye out for one of these first, and if after as while I don't find one, look to the other solutions proposed.
    Thanks!
    1954 Light 15
    1970 DS21 BVH
