2CV Windscreen Wiper.
Results 1 to 14 of 14
  • 1 Post By robmac
Thread: 2CV Windscreen Wiper.
    Albany WA
    229
    Default 2CV Windscreen Wiper.
    Does anybody know if there is some way to have a two speed windscreen wiper attachment?
    We get plenty of rain in the South West (Albany).
    Herman
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,856
    Do you want a faster speed or a slower speed than the one you currently have? What battery voltage does your 2CV run from?
    Cheers, Ken
    Albany WA
    229
    Quote Originally Posted by Ken W View Post
    Cheers, Ken
    I want a slow one and I have 12 Volts.
    Regards, Herman
    Jul 2004
    CLARE SA
    2,323
    if you are an after market fiddler Herman ...
    your local auto wrecker is likely to have hundred of options
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Get one of these and choose your own speed
    https://www.aliexpress.com/item/DC-6...ceBeautifyAB=0
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    18,038
    Just remember, the "speed" will never be faster than a standard wiper motor.
    with apologies to Judy Grahn
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    I was just assuming after the battery voltage question that the car had been converted from 6 to 12 volts and the wiper motor is still the 6 volt one and the wipers are going to fast and the OP wanted to slow them down, so suggested this as a cheap easy fix.
    Regards Col
    1973 Alpine A110
    18,038
    My post wasn't intended as criticism.
    Simply clarification, for the OP who may not grasp the technicalities.
    COL likes this.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Thanks Rob no offence taken, I probably should of clarified "choose your own speed"
    Regards Col
    1973 Alpine A110
    North Brisbane
    1,856
    Fit an intermittent wiper control board like the one below. These were really popular in the 60s and 70s electronic magazines as kits.
    https://quasarelectronics.co.uk/Item...per-controller
    Cheers, Ken
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Cheers, Ken
    These were the go before manufacturers fitted intermittent wipers as standard kit.
    Regards Col
    1973 Alpine A110
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Cheers, Ken
    Get both kits then you can control the speed of the wipers and how often the wipers wipe the screen
    Regards Col
    1973 Alpine A110
    Albany WA
    229
    Thank you all for your help!
    Herman
    Lavers Hill
    309
    If you don't want to make up a kit of electronics to make an intermittent wiper, you could get an intermittent module from an appropriate wreck. Bosch made one used on several cars in the 1980s and 90s, with a variable interval. We used to own a Lada Niva, they came with a terrible, crude intermittent module from the factory.
    There was a period, early 1990s, when new Nivas arriving in Australia were taken to Peter Brock's company and had quite a bit of work done to make then comply with Aussie regulations, and to be a whisker more reliable. Ours was one of these, a 91 model. One of the changes was to fit a Bosch intermittent wiper module. The original Russian one was disconnected and left in place, an adapter harness was made up and used to join the Bosch module to the existing wiring. TheBosch module was set to a particular setting and just shoved up under the dashboard, you could not adjust the interval only because no knob was fitted to the shaft, and it was stuck in an inaccessible place. The car had only 2 wiper settings, Fast and Intermittent. (same as the Russian set up, except the Bosch module worked better.)
    So...If you can find a wreck of a 1990 to about 1993 Niva, rummage around up behind the dashboard, more or less where the floor mats finish, and you should find a good quality variable intermittent module. You will need to find a knob to go on the adjuster shaft if you want variable interval. It is above the LEFT footwell.
    These modules were also used on more normal cars of the period, but I can't remember which ones. Early Commodores rings half a bell, but only the posh models had intermittent wipers.
    Your wipers still move at fast motor speed, but the module introduces a pause between sweeps.
    In case you aren't sure how they work, here is an explanation... The module is basically a simple timer, every so often (adjustable by turning a knob) it emits a very short pulse of 12 volts to the output wire. That wire is connected to the power supply to the wiper motor. This burst of electricity moves the wipers a little bit, once the wipers are moved a few cm, the pulse disappears but the wipers are no longer in the park position, so the self-parking circuit kicks in and the wipers continue till they are neatly back in the park position. (or still sticking up like 2cvs do...) There is a bit more to it than that, as the self parking circuit needs to be switched out of the circuit when the pule first arrives, to avoid the self park circuit shorting the pulse circuit. But that is all controlled by the module, as long as it is wired in correctly.
