Xantia CT Turbo heater hose ?
Results 1 to 7 of 7
    Coffs Harbour, NSW, Australia
    599
    Default Xantia CT Turbo heater hose ?
    For, '97 Xantia CT Turbo 2.00
    I require a replacement heater hose assembly for the above.
    Usual eBay searches have failed. One supplier in Turkey replied to a message saying they could supply, but two subsequent messages have failed to reveal how I can order & pay for it ?
    No go at EAI, Lorreante, & one eBay German outlet.
    Any ideas please ?
    Richard
    9,306
    Richard, I don't have the part, but I'm guessing you want #6 in this diagram.
    If the fault is at the elbow that fits to the heater core pipes, as it often has been, you could probably take one from any of a number of Citroen and Pug models and splice it in. Some models have the elbows pointing straight down while others are at an angle.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    7,915
    Or if you are really desperate and are losing too much coolant because the crappy plastic heater pipes are broken, you can bypass the whole heater by fashioning a copper plumbing tube to connect the coolant hose to itself behind the engine. That's what I did so that our Xantia is still usable. Fortunately Sydney winters are not that cold that one needs the heater.
    John
    Ici.
    2,408
    does anyone know if Pug 406 bits fit this spot?
    599
    Apparently Peugeot 306 hose fits. Mine has split at the elbow where it connects to the thermostat & I have taped it over, but if I can't get a new hose I will cut & sleeve a elbow into the line. As usual you have to demolish the car to get at it !
    Thanks everyone .
    Richard
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,253
    Mine has just burst also and have done just what your saying. My top main hose from thermostat to rad was bulging. There are definitely NLA. Lucky a friend had a spare car I could rob it from.
    Preston, Melbourne
    252
    I had to adapt mine from another slightly different Xantia too. I guess a couple more points of failure but gave me no problems.
    Sent from my LG-H815 using Tapatalk
    06 Citroen C5 Estate 2.2 Hdi Auto
    95 Peugeot 306 S16
    95 Silver Xantia VSX - now deceased
