Steering Angles Light 15?
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By gerrypro
Thread: Steering Angles Light 15?
    Member Artificer's Avatar
    Mar 2018
    Robina
    47
    Default Steering Angles Light 15?
    Updating current old belt driven pump, power steering rack & pinion & fitting late model remote electric power steering rack to my '49.
    Interested in ALL 'optimum' steering angles [adjustable or not] on late '50's model light 15's.
    Toe in & or out
    Camber & caster
    Did a search & only found toe out.
    Any help, suggestions etc. welcomed & appreciated. John.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,958
    Light 15/11BL/Big15/11Normale
    Caster Angle 1 Degree 30 Seconds +/- 15 Seconds.
    Toe Out 0-2mm. I try for 1mm.
    Camber Fixed setting given heights and weight distribution are correct 1 Degree +/- 30 Seconds.
    Track rods must be equal in length or Ackerman Principles will be compromised and wheels will scrub on lock.
    A Table of Heights is to be found on page 133 of the work shop manual.
    15CV/Big 6.
    Caster angle 0 Degrees +/- 15 Seconds.
    Toe Out 0-4mm
    Camber 1 Degree +/- 15 Seconds
    Height adjustments Paragraph 1 Page 140 of the Six Cylinder Workshop Manual
    Trading Estate and JohnW like this.
    Cheers Gerry
    Mar 2018
    Robina
    47
    Many thanks Gerry, JG
