C5 X7 2011 HDI Interior Front Map Light Switches
    Feb 2014
    Sydney Australia
    37
    Default C5 X7 2011 HDI Interior Front Map Light Switches
    Hi, how do I remove the top front interior MAP Light Cover so I can have access to the cables as well as replacing the lights with LED ones? I also need to find a way to get power from there so I can connect a Video Cam Recorder rather than having cables running everywhere. Anything on utube? Or examples showing pictures of how to do this. tx
    8,763
    It clips on. Use plastic trim tools. C5 X7 2011 HDI Interior Front Map Light Switches-screenshot-2.jpg LEDs will work but the computer will record an error unless the resistances match.
    PS there are a couple of screws in the middle.
    Jul 2013
    Newcastle/ central coast
    1,936
    There is ignition fed power at the dome light
    8,184
    Icon3
    Quote Originally Posted by Johannes2118 View Post
    This is for a C4 Grand Picasso but should be much the same for the C5 X7
    08 C5 X7 HDi very Noir
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    I obtained power from the fuse box in the glovebox for my dash cam and just ran the cable up the A pillar.
    If you like I can check which fuses I used for both ignition and constant power.
    pm me with your email address it you would like to see a pic. I don't know how to host a picture now that photbucket has died.
