BW35 stubborn plug
Results 1 to 22 of 22
Like Tree7Likes
  • 1 Post By driven
  • 1 Post By DoubleChevron
  • 1 Post By robmac
  • 2 Post By UFO
  • 2 Post By Citquery
Thread: BW35 stubborn plug
    Dec 2010
    263
    Default BW35 stubborn plug
    What is it?
    The 3/16" Allen head plug shown in the attached photo closes the tapping point for monitoring the pressure in the BW35 transmission fitted to my 1974 DS23 (carby).
    I have so far been unable to remove it using 3/16" Allen keys and welcome suggestions as to the best way to tackle it. There is about 200 mm space between the plug (located on the side of the transmission housing) and the front sidemember.
    Why is it important?
    It is well documented that automatic carby DS23s are typically on the sluggish side; mine is lethargic in the extreme and I suspect the auto trans stator may be slipping, so I want to perform the stall test as described on page 196 of the 814 part 1 workshop manual.
    The work required to correct this problem is substantial; hence my interest in performing the stall test.
    Attached Thumbnails Attached Thumbnails BW35 stubborn plug-bw35-pressure-plug.jpg
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    Well it will be a metric size anyway - probably 5mm. Is it slipping yet? Do you have some 3/8 square drive metric allen key sockets? Maybe visit the tool store and get a half inch drive impact driver type for a bit more strength.
    Cheers, Ken
    Dec 2010
    263
    Thanks for your reply, Ken W.
    I think the impact driver route - with heavier Allen key sockets - is the way to go; however, it is definitely 3/16". 814-1 says so and I've tried a 5mm and it doesn't fit, whereas 3/16" does.
    The main symptom of concern with the trans is very sluggish take-off, which I understand is indicative of a slipping stator.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    543
    Not sure what you are going to check by removing the plug . I thought a stall test was foot hard on brake , hold throttle pedal to floor and note what engine revs to with car " stalled " , from memory it should be about 1750 rpm.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Dec 2010
    263
    I believe you are correct, Rally - as far as the stall test is concerned; however, I also want to check the ATF pressures, as specified on page 196 (Op. D.bw 354-0 page 5) of the 814 (part 1) workshop manual.
    1000+ Posts driven's Avatar
    Apr 2005
    1,442
    Apply Chemsearch Yield to any thread that is not moving.
    It is super wick in compound but the best, saves fracturing, breaking, stripping the head or bolt
    JohnW likes this.
    North Brisbane
    1,928
    The steel allen key plug will have grabbed onto the threads of the aluminium gearbox casting over the last 40+years. So good luck getting it to loosen nicely.
    Cheers, Ken
    Dec 2010
    263
    Thank you, driven and Ken W.
    I was unaware of Yield, but some further research has turned up some more options: and
    The RR thread suggests auto trans fluid and acetone. Perhaps I should just add some acetone to the ATF (which is already there)!
    Seriously, I might try a couple of these (Yield and Loctite) and see whether they break the bond between the plug and the casing or whether the two are effectively welded.
    By the way, an MGB BW35 service manual says the recommended torque for this plug is 4-5 ft lbs; Citroen just says "fit the plug".
    16,426
    Do you have an impact driver there ... Something like this:
    https://www.ebay.com.au/itm/Impact-D...item213eb440cb
    If that didn't work .... I'm move straight onto my rattle gun ...... And hope like hell I don't wind the threads out of the aluminium housing as the plug comes out!
    Try candle wax first though. I've seen it work miracles.
    a small butane torch is all that is required (you don't need a big oxy set). Its amazing what using candle was releases.
    UFO likes this.
    Newcastle
    2,623
    Hi
    Shane what setting would you use on your rattle gun for a 3/16" allen hex adapter ??????????????????
    I suggest the heat gun for an initial soften up and as you have restricted space some of the suggestions are impractical.
    I would then use 3/16" hex to 10mm bit that i have with a 10mm ring for turning and a second person applying a hit to the top of the bit with a lump of flat bar or similar and see how it goes. You will be able to feel the effort applied and any turning.
    good luck, Jaahn
    PS I would also try a transmission flush in the oil to see if that will clean out any gummy deposits from underuse and may be causing the lockup clutch to slip. Have to get the transmission hot for them to work. A stall test will do that
    16,426
    Hi
    good luck, Jaahn
    Yeah I would use a socket and extension to the rattle gun if I could. I've never worked on the automatic version. So am unsure of the placement of the plug. Be warned, using extensions on your rattle gun reduces its effectiveness enormously. I've not been able to undo wheel nuts in the past with my big 3/4" rattle gun ............ I removed the short extension bar and they unscrewed straight away!
    Apr 2005
    1,442
    Bush Mechanic again
    Drill plug out on centre with a large diameter drill, loosens grip on thread, may need several goes
    OR
    Drill through as above, retap plug hole with smaller size and screw in bolt to seal, easy
    OR
    Weld on a rod to plug and easy tap to remove.
    19,098
    Bush Mechanic again
    OR
    OR
    The latter method is sound, albeit as a last resort.
    However, the former suggestion has a serious flaw , the risk of introducing metal swarf into the service port of an automatic trans.
    When I went to school , cleanliness was an essential part of keeping autos working properly.
    JohnW likes this.
    Dec 2010
    263
    Thanks for all the suggestions and comments, everyone.
    Getting back to my original issue (suspected slipping stator); the ATF looks OK, but it has been in there a long time (if not a lot of miles) and I wonder whether there's some merit in jaahn's suggestion: I would also try a transmission flush in the oil to see if that will clean out any gummy deposits from underuse and may be causing the lockup clutch to slip. Have to get the transmission hot for them to work. A stall test will do that - or even just a couple of drain/refills with Type F ATF (the brew that's recommended for the DS23 BW35), as it only yields about 2.5 litres (of the 6 litre capacity) per drain.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,254
    The 2.5 litres is the 'change' amount as per the book. There is a lot in the torque converter which is never drained in the old style auto's. The BW35 is the automotive tranny whore of the '60's, '70's and '80's!
    You need to get the ATF hot and a dose of cleaner is needed. I'm sure Nulon etc do a tranny cleaner/voodoo additive to un-gum the pistons and such. Use as directed and results may not match the pictures.
    Brendan.
    Newcastle
    2,623
    Hi
    You should do both, the flushing 'voodoo' additive first, drive etc, and when you drain, leave for a long drip time, a day. Probably get another 0.5-.7L more out. Then run for a 'bit' and then change again, same method. Then refill again also with the 'voodoo' stuff. Get it hot every time and for a few Ks in the hills to circulate the fluid and flush the shit out of the converter and all the other nooks and crannies.
    I was told to do that back in the '70 with the father inlaws' 2 speed powerglide Kingsy which was playing up after very little use. Fixed it up presto and restored it to slushmatic 2 speed glory
    Bon Voyage Jaahn
    Dec 2010
    263
    Thanks for your additional thoughts, jaahn.
    CitroŽn Tragic UFO's Avatar
    9,721
    Hi
    Bon Voyage Jaahn
    bluuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuurrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrr [scenery going past]
    [pause]
    bluuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuurrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrr [scenery going past slightly faster]
    jaahn and bluey504 like this.
    Feb 2011
    brisbane Au
    927
    Try holding a short drift [of some type of material] against the plug and give it a good once only hit with a large hammer [large because of the restricted amount of available space for a normal swing with normal size hammer]. That method usually loosens these type of plugs.
    Dec 2010
    263
    Plenty of time to view the scenery in my D, UFO - especially when going uphill!
    Thanks for the suggestion re the use of a hefty persuader, shanadoo.
    Jan 2011
    netherlands
    45
    Quote Originally Posted by Citquery View Post
    What is it?
    Hi, it's normal metric thread. Heat the area up until you can unwind.
    cheers,
    Harry Martens
    Dec 2010
    263
    Thank you, Harry.
    For those who aren't aware of Harry, it's worth visiting http://ds-vitesse.com/en/ or searching Harry Martens Limmen Citroen
    forumnoreason and dsvitesse1 like this.
