CX not starting... - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 54
Like Tree15Likes
Thread: CX not starting...
  1. #26
    10,267
    Bugger. There must be something. And it will be obvious with hindsight.
    So what has NOT been verified?
    1. That solenoid is (a) getting power with the ignition on, (b) getting power WHEN CRANKING and (c) operating when it has power
    2. Independent review of timing (sorry.....)
    3. Are any vacuum lines disconnected allowing too much air into the wrong holes? There should be one to your non-existant distributor vacuum capsule (does it REALLY not have a vacuum advance?) and another from the funny air-solenoid that slightly opens the throttle when AC is switched on (there's a little air capsule device on the carby with a pipe to the solenoid device near the radiator expansion chamber).
    4. Something else? I can't imagine what. However, the fact that the accelerator pump squirts doesn't mean a jet isn't blocked. Be nice if a good CX person were close enough to come and have a look.
    Do you have a workshop manual?
    Mine stranded me a few weeks ago as a jet had come loose in the float chamber. Rush hour, stuck in a bus lane, overwhelming traffic volume and overwhelming traffic noise and the RAC refused to touch it in the bus lane (I was 80 m from a side road.....). Flat bed for a few minutes with a screwdriver (once diagnosed of course....).
    Hmm. As before, best wishes.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  2. #27
    Sep 2005
    178
    It sounds very much like a dead condensor to me.You can piggyback on another one to test this suggestion. Hawk
  3. #28
    Armidale
    2,010
    Quote Originally Posted by 37dhw8 View Post
    Hi Alec,
    I have a ballast resistor installed with my new coil.
    Leads are in the distributor cap in the order 1-3-4-2 clockwise (have confirmed that this is the direction my distributor turns). Did this all according to the instructions set out for 'test lamp' in the Haynes manual - everything checks out OK. Rotor is at lead 1 at 10 degrees before top dead centre, according to the flywheel markings.
    I had been spraying the starting fluid right down the barrels of the carb - is this wrong? Choke was off whenever trying to start with fluid.
    I took the top off the carburetor yesterday, and the float bowls looked to have a decent amount of fuel in them.
    Probably something stupid I'm forgetting honestly. Absolutely stumped.
    Thanks so much for all your help !
    Well you really are eliminating a lot of possibilities! Sorry to have implied you might be doing something stupid - you really seem to be eliminating all these possibilities quite logically (at least as far is possible without any diagnostic equipment).
    Re the starting fluid - yes down the carby throat should be fine. On a fuel injected car, usually if you disconnect the airfilter you will have an intake tube leading to the throttle body - wasn't sure of the setup in the CX.
    Alec
  4. #29
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,931
    Hi Alec,
    You say rotor is at number one lead with fly wheel marked at 10 degrees BTDC. Are the exhaust and inlet also both closed on number one cylinder? ( flywheel end ) If not the dizzie is 180 degrees out!!!!!!!
    Armidillo and JohnW like this.
    Cheers Gerry
  5. #30
    Jan 2018
    melbourne, australia
    34
    I have confirmed that the jet with fuel happily being sprayed out of it is the accelerator pump jet, but I can't confirm the other ones. Is cleaning as simple as unscrewing them and soaking in carb cleaner?
    79 cx2400 pallas c-matic
  6. #31
    Dec 2010
    Wollongong, NSW
    470
    How good is the battery? I vaguely recall that I couldn't get a CX to start on a cold morning, even with a jump start. I could only get it to start if I put the good battery actually into the car itself.
    I haven't read this thread entirely, but has anyone suggested putting 12 v directly to the coil temporarily and then hitting the starter?
    Regards, Erik
  7. #32
    Feb 2013
    439
    Try something simple. Disconnect the tacho from the coil. CX not starting...-97e8bdc8-231f-4a0f-ac5d-e46ca4e89c55.jpg
  8. #33
    10,267
    Unscrew yes, inspect against the light to make sure there isn't a simple particle of dirt blocking it/them and blow it out. Carbie cleaner won't dissolve junk necessarily. In line with earlier comments, I imagine they'll be clean! They need to be pretty tight when going back in, but not ridiculously so.
    You do know the way the coil works? The ballast resistor runs the coil at reduced voltage when the car is running, but is by-passed when the starter is activated, getting the full 12V to the coil. Hence Erik's sensible suggestion.
    Renault 4CV 1951
    Renault R8 1965
  9. #34
    Jan 2018
    34
    Quote Originally Posted by Erikbm View Post
    Regards, Erik
    The battery is good, I think... I'll have to try using the battery from my dads car (a prius) and hope it's powerful enough. I've had similar issues when trying to jump start! The car was just turning very slowly. I'll try another battery and see how we go.
    I've tried temporarily bypassing the resistor, to no avail. If it means anything, on the inside of the resistor (it wasn't sealed or anything), the material around which the resistance wire was wrapped was split and frayed.
  10. #35
    Jan 2018
    34
    Quote Originally Posted by Jinandfonic View Post
    Try something simple. Disconnect the tacho from the coil. Click image for larger version.
    Interesting... I found the tacho wire, loose in front of the radiator. Doesn't look like it was connected to the coil in the first place...
    Jinandfonic likes this.
  11. #36
    Jan 2018
    34
    OK so as a final idiot check I turned the plug leads 180 degrees ... car cranked for a bit and backfired LOUD. Does this make me closer to the solution or further away?
  12. #37
    2,931
    You got a Bang!!!! That means there is some form of ignition happening. Go back to basics. Remove the rocker cover and set the engine so that inlet has just closed and is coming up onto compression for number one ( water pump end ) watch through the bell housing aperture and turn the engine until the 10 degree mark lines up with the notch in the aperture. I use a large screw driver to slowly advance the crank until the correct advance before TDC is reached.
    Make sure that the engine is turned anti clockwise looking from the water pump end. Your levering movements with the screw driver will be toward the rear of the car.
    (Lever on the ring gear teeth with the driver, working through the timing sight apperture). Now set the distributor so that the rotor points to the number one lead. You should then be at 10 degrees BTDC ( before top dead centre). Lock the distributor clamp bolt here.
    Cheers Gerry
  13. #38
    Armidale
    2,010
    Well the backfire means you've got fuel and spark ! It also means that at least one cylinder is currently firing when the valves are open - sounds like it was better the way it was before.
  14. #39
    Jan 2018
    34
    I set the timing according to your instructions, Gerry, and still the best I can get is that slow r-r-r-r pausing from the starter motor. Fearing I might have worn out the battery, I'm leaving it to charge now. Is it possible that the cranking speed has been too slow right from the beginning? It's always been very slow but it does feel as if it would go if the cranking speed was faster.
  15. #40
    Ici.
    2,373
    Could the starter solenoid be cactus?
  16. #41
    10,267
    Mine starts from cold on full choke even if it barely turns over due to low battery after a couple of weeks of non-running. There's something else and it does smell electrical as someone said at the start....
    Just saw the "bang" email. Back to ignition timing...… Is there an CX owner anywhere nearby???
    Renault 4CV 1951
    Renault R8 1965
  17. #42
    10,267
    It spins, sparks and tries to fire, even going "bang". Not the solenoid I'd suggest.
    Renault 4CV 1951
    Renault R8 1965
  18. #43
    Jan 2018
    34
    yeah... If anyone is near East Malvern area I'd love your help - there's a reward to whomever manages to get it started, haha.
    I'm completely out of my depth here. Perhaps people would like to recommend a mobile mechanic?
    Thanks for all your help
  19. #44
    10,267
    Do you belong to a Victorian club?
    Renault 4CV 1951
    Renault R8 1965
  20. #45
    Jan 2018
    34
    Yes, I'm part of the CCCV
  21. #46
    2,931
    Good question! I would recommend 'The Citroen Car Club of Victoria'
    https://citcarclubvic.org.au/
    Cheers Gerry
  22. #47
    10,267
    I suggest you shout for help! This might be something quite obvious to someone who knows the CX well.
    Renault 4CV 1951
    Renault R8 1965
  23. #48
    Ici.
    2,373
    thats a case of beer job righr there!
  24. #49
    10,267
    Any joy?
    Renault 4CV 1951
    Renault R8 1965
  25. #50
    16,154
    if its backfiring. You still have the timing wrong. You have fuel and you have spark for a backfire. The timing is just wrong. You need to set it statically first.
    Find Top Dead center on the compression stroke. He is using his finger to see if there is compression (I've never had sucess with this as access is always to restricted). So find the compression stroke (use a length of fuel hose down the plug hole, you will hear it hissing when you find compression). Once you hear it hissing, put a drinking straw down the plug hole and turn the motor over until the drinking straw is at its highest point. This is top dead center on No1.
    Now, does the timing scale point to around 0degrees If its not, double check you are on the compression stroke. If it still isn't right .... well that sucks, your timing marks are wrong. Now move the engine until it points to about 10degrees on the timing marks if you can.
    So this is the spot the engine should run at ... and probably be quite ok to leave at without any further messing around.
    unscrew the distributor cap. mark on something that shows where the rotor bottom is pointing (eg: a hose nearby or bit of body). refit the distributor cap. Is the rotor button pointing to No 1 ?? If it isn't rotate the distributor until it does. If you can't rotate the distributor enough, you need to pull it out, rotate the dizzie so it points near enough to number 1 as you drop it back in. Or.... Pull all the high tension leads off and plug No 1 in where the rotor bottom is pointing.
    now grab a multi-meter or test light. Slowly rotate the dizzie until your light goes out (ie: the points open). You will need to check the points gap before doing this.
    spin the engine over and watch which way the rotor button spins. In this direction plug in the rest of your HT leads. 1 then 3 then 4 then 2 .....
    It should now start and run if you have spark at the plugs and fuel.
    JohnW likes this.
