CX Testing Voltage at the Injectors Query
    Apr 2017
    Ballarat, Vic
    12
    Default CX Testing Voltage at the Injectors Query
    Hi Everyone, does anybody know how to pull off this plug circled in the photo above without breaking it? Its off an 1985 CX IE Pallas 25. cheers.
    Attached Thumbnails Attached Thumbnails CX Testing Voltage at the Injectors Query-img_2376.jpg
    16,426
    Oh, push on the wire clip at the bottom
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    With those plugs, I usually get a small screwdriver and take off the spring clip to take the plug off, then I refit the spring to the plug so it will push on and clip into place securely.
    Cheers, Ken
    16,426
    Yeah, I've broken a few of those clips. In theory if you press dead center along the middle of the spring ... it'll pull back the wire legs and they come off. Sometimes its not easy to get the screwdriver under them to get them off.
