Suggestions re sourcing a D "feed tube union"
Results 1 to 8 of 8
    133
    Default Suggestions re sourcing a D "feed tube union"
    I need to get a new "feed tube union" part number DS 174-82 for a 1971 D special. It's the bit that connects a nylon pipe to the metal piece in the fuel tank.
    Does anyone agree that the De Franzose part 32239 is the very same ? ( despite their off putting parts description )
    Nostalgia.....aahh It's not what it used to be
    8,185
    Icon3
    Quote Originally Posted by dayofthejackal View Post
    I think the Der Franz part is for an injection car and by description is fitted somewhere under the bonnet?
    The part you require is listed here, but that is an off the planet price for a piece of fuel hose. . . part #9 used in two places in the diagram linked.
    https://mundotraccion.com/tienda/en/...osito-gasolina
    I'd be measuring the OD of the Rislan and steel tube and checking what can be had at your local automotive store.
    08 C5 X7 HDi very Noir
    133
    I think I need part no 3 not 9
    Jun 2015
    Ashburton
    199
    Agree with Chris. It’s just a rubber pipe. Find a close fit locally.
    Feb 2012
    Ongar / England
    832
    Hello, is this it? As Chris and Co suggest, just a piece of fuel resistant pipe.
    Sleeve to seal fuel line to tank 1966
    Apr 2016
    Bedford, UK
    708
    Quote Originally Posted by badabec View Post
    I think you're right. Part DS 174-82 is 280mm long. So is the part from Citroen Classics. I think Franzose sell a kit with this part in it too. Part 32346: https://www.franzose.de/en/Citroen-D...hoer/ANR32346/
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    691
    Just a gotcha here.
    The factory part has two diameters - the replacement only one.
    There is only one clamp on the factory rubber IIRC which is the metal side.
    Because the replacement is one diameter it is vital that the replacement is clamped both ends (preferably ligarex).
    If you don't fuel will work it's way up the gap between the nylon tube and the tank metal guide tube and spill everywhere.
    Don't ask me how I know....
    Mark...
    Jan 2012
    173
    Regular old fuel hose does the job nicely. Can't remember the exact size I used but pretty sure it was 5/16", easily obtained at repco, supercheap etc. The rilsan tubing has an 8mm outer diameter.
