D special: ‘Pulsating’ lights
Results 1 to 12 of 12
    Aug 2011
    406
    Default D special: ‘Pulsating’ lights
    Dear brains trust
    The lights (both interior and headlights) on my D special ‘pulsate’, or vary in their brightness.
    A quick google search suggests that this could be related to battery connections and grounds (clean and tighten etc) and/or to alternator bushes or the regulator.
    I will go over connections etc first, but is there anything particular to a D that might be applicable? In what order should I be eliminating possible causes?
    Regards
    AM
    Apr 2014
    Phoenix, Arizona USA
    643
    Probably the mechanical voltage regulator. It oscillates between a low and high charge setting to keep the battery at approximately 14.7 volts. Replace it with an electronic regulator (e.g. Ford Mustang) and the pulsing will likely go away.
    John T.
    Jan 2017
    mulgrave
    71
    AM,
    I had the exact same problem and I had a Bosch electronic, 2-wire regulator.
    As was explained to me, it was caused by a slightly unstable regulator reference voltage (because the circuit came via the instrument panel and a few volts might have "got lost")
    The easiest solution was to put a relay in with a feed coming direct from battery. It fixed the problem immediately
    I can send you the circuit if you want.
    Ian Downie
    Blueduck (aka Ian Downie)
    1974 Citroen D Special with DS21i.e. engine and 5 speed gearbox
    MGB GT V8 B.... bullet--proof and great fun
    Jaguar e-type roadster ... on the way from US of A
    Jun 2015
    Ashburton
    178
    Hi a
    my solution was to replace the alternator with a new one with an internal regulator. Not very expensive, hard to tell the difference and very reliable. Got mine from atelier 524
    peter
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    435
    See also here.
    Even though... in the end... if the battery gets properly charged (you may want to get a $5 voltmeter and stick it in the lighter socket) a bit of flickering does go with the territory
    They have a pulse, they have a soul...
    If it doesn't, or if it bothers you, new alternator with new regulator, will fix it.
    Apr 2016
    Bedford, UK
    633
    Quote Originally Posted by blueduck View Post
    AM,
    Ian Downie
    I'd be interested in seeing the diagram Ian. Can you put an image up with a post here perhaps?
    Budge
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Jan 2017
    mulgrave
    71
    It was clearer to me 3 years ago but that is it.
    Note The new and additional regulator and the connections to it
    Note external Bosch regulator ... just 2 wires.
    Note the wire you must cut
    Ian
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,867
    The case of the RE55 needs to be well connected to chassis or battery negative and it is best mounted close to the battery with the relay.
    Cheers, Ken
    Apr 2016
    Bedford, UK
    633
    Ian
    Thanks Ian. I think i get it. I'm working with an original external Ducellier VR and my car's not an efi, but I think i get the principle. I can see where the wire that would have run from the ignition to the Bosch has been cut and taken off to the relay instead.
    10,638
    AM,
    Ian Downie
    I had an identical problem and was suggested an identical solution. It was and is an Australian Bosch alternator in a Renault R8. I used the feed voltage to the regulator (from the ignition switch) to operate a relay that switched 12V from the positive on the alternator to the regulator (30 cm wire length) and the problem disappeared. It happened with both old-school regulators and newer solid state ones.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
    Apr 2014
    643
    Many years ago, I wrote an article describing how to install a Ford voltage regulator in a DS BVH. For BVM (an SM) it is much simpler since you don't have to worry about the starter inhibit circuit. One advantage of the Ford (and possibly other) regulators is you can wire the "A" terminal directly to the battery (or the battery post on the alternator) since the Ford VR self-energizes through the indicator light to close the high current field relay (transistor, actually). This means the field current is no longer sourced through the ignition switch.
    John T.
    Apr 2014
    643
    Here is an enlarged diagram showing the Ford VR in place of the original. Optionally disconnect and insulate the ignition switch lead ("BOB") to the VR (broken line in the diagram) and wire the VR directly to the battery (red line in the diagram) using a 30A fuse. This allows the field to be energized directly from the battery without going through the ignition switch.
    John T.
