cx steering rack leak
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By Ken W
  • 1 Post By DoubleChevron
Thread: cx steering rack leak
    Jan 2018
    melbourne, australia
    49
    Default cx steering rack leak
    hi guys,
    i have had a roadworthy test from paris motors and they commented on a 'steering rack leak'. i don't know whether it's an internal or external leak, but i don't notice any lhm on my driveway.
    should i recondition the steering rack with new seals etc ? or if it's an internal leak, should this be affecting roadworthy status at all ?
    thanks very much for your help.
    regards,
    max.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,952
    If the rack has to come out then it is well to do the whole job. Parts from CX Basis. One of the hydraulic rams ( the smaller diameter one) in the rack can suffer from corrosion and new seals alone will not fix it. The job is within the capabilities of a competent home mechanic.
    Cheers Gerry
    16,156
    Have a look. It may just be the return lines. Racks I've found generally leak through the boots.... and into the inner tierod joint.
    9,404
    Yes, check the T in the return line from the control unit above the pinion. It can look like a rack leak.
    Melbourne, Victoria.
    1,386
    I did that job on my CX about 12 years ago. The seals kit cost me about $200.00. It was a simple job but it took me one day doing it very carefully. Good luck.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,856
    You have just reminded me that reconditioning the rack on my CX Wagon is also on the list when I finally get the steering and suspension sorted on the Xantia Wagon - I suppose it will never end.
    Ken
    JohnW likes this.
    Jan 2018
    49
    I know bandaid fixes are never a good idea ... but what about power steering stop leak? https://www.wynns.eu/product/power-s...op-leak_tubes/ This claims to be compatible with Citroen LHM systems, and I've had good experiences with Wynn's stop leak products in the past for rubber seals in the engine oil filter mount. Hoping someone can shed some light on this.
    79 cx2400 pallas c-matic
    16,156
    Quote Originally Posted by 37dhw8 View Post
    DO NOT ANYTHING IN THE HYDRAULIC RESERVOIR OTHER THAN LHM..... This isn't *just* simple power steering, it is your brakes, suspension and fully powered diravi steering controller and rack. ie: NOT just a crappy pump and rack!
    UFO likes this.
    North Brisbane
    1,856
    Have you discovered where it is leaking from? If it is into the passengers side rack boot - LHS side of the car, you can do a quickie to replacew the O ring seal on the ram side of the rack. Just take the tie rod off the rack, undo the huge nut, withdraw the shiny ram cylinder, replace the outer O ring on the rack outer, replace the ram cylinder and the nut, tierod joint, boot etc. This will last you for a while until the O ring on the other side needs replacing and that is a rack out jobbie.
    Cheers, Ken
    Apr 2013
    Essendon
    576
    Max, may we assume that you got your R W C and you are concerned about the health of the system in general.
    If you got the vehicle registered, and the power stee works, why worry about Paris Motors saying you got a leak that does not show on your driveway?
    9,404
    Leak has become worse apparently. There really isn't much option but to dismantle and reseal, although Ken's interim fix might save the day and defer the inevitable.
    10,492
    Best to bite the bullet and just fix the whole thing. Easy for me to say of course.
    Good luck with it.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    10,492
    As they do. Sigh...…
    Renault 4CV 1951
    Renault R8 1965
    Jan 2018
    49
    the r w c has not been attained ... it's been a long journey
    bringing her into Paris Motors tomorrow hopefully for repairs. as much as i'd like to do it myself, i'm very low on time at the minute and so this is probably the best way to go. fingers crossed ....
