CX Starter Circuit
Results 1 to 7 of 7
    May 2011
    Cootamundra, NSW
    42
    Default CX Starter Circuit
    Can anybody explain to me what this is supposed to achieve. Yes, it is a 6 ohm (or thereabouts) resistor, with another 1.5 ohm one not connected. The way it is wired up, it simply connects the key start circuit to earth when operated - but why, when that just adds a couple of amps to the key switch load? Might there be a wiring error, perhaps? Or ... ?
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,952
    It doesn't look original! Why has it been added!
    Cheers Gerry
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,856
    Maybe it is there to quickly remove the inductive energy from the starter solenoid coil when the starter has done its work and the key is released?? A reverse diode would be a much more efficient way to do that though.
    Cheers, Ken
    May 2011
    Cootamundra, NSW
    42
    Quote Originally Posted by Ken W View Post
    Cheers, Ken
    Agreed, but when the key is released and the relay cuts off, it is only connected back to the key, not the solenoid coil. Hence my suggestion that, at least, I have a connection problem.
    PB
    North Brisbane
    1,856
    So there is a starter relay installed - that is an upgrade as well - a worthwhile one too.
    Cheers, Ken
    May 2011
    Cootamundra, NSW
    42
    Cheers, Ken
    Friends, I think we have an answer. Without a starter relay, low current flow is possible from the key switch cable to ground via the starter motor solenoid. This has something to do with a connection to something ... - more likely not the Citroen Eye, but the L-Jetronic Injection and its peripherals, which comes into (or off) the key switch lead at some indeterminate location. So, once a relay is installed, that is lost, so a separate ground connection is required - but through a resistor as a means of limiting current when not in the actual start position. Therefore, a new starter relay and a bit of tidying up of wiring may be all I need!
    North Brisbane
    1,856
    So it is fuel injected as well.
