Traction Steering Geometry
Results 1 to 8 of 8
    Apr 2014
    Phoenix, Arizona USA
    674
    Default Traction Steering Geometry
    My recently-acquired TAV does not currently run, so we had to winch it onto the trailer and push it into the garage. While pushing it, I noticed that if the car is turned anything more than about 45 degrees at the steering wheel, the tires begin to really scrub (making it really, really difficult to push). Is this normal or is it an indication of something seriously amiss in the steering geometry?
    John T.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    Track rods need to be equal in length and the wheels need to toe out 0-2mm. I like a 1mm toe out! The pitman arm is a keyed taper in the steering swivel. Sometimes the key can shear and the arm twists off line. This situation can produce some really weird geometry on lock and is potentially dangerous. A rough setting for the caster angle is 2-3 threads protruding at the front of the upper link arm pivot shaft. A simple caster angle gauge is shown in the manual and is easy to make. The drawing has a labelling error but is easy to work out. If you have checked out all of the above and it is all according to 'Hoyle' then something else may be bent or badly worn. It is possible to bend a lower link arm but very rare!
    Cheers Gerry
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Guys,
    I agree with what Gerry has suggested, but your problem may also be someone has fiddled with the end adjustments on either end of the rack to decrease the turning circle?
    Best regards,
    Greg
    We Have:
    We Had:
    617
    Hi Guys,
    Best regards,
    Greg
    We Have:
    We Had:
    Apr 2014
    674
    Thanks for the replies. This confirms my suspicion that Citroen designed the TAV to have proper Ackerman steering geometry, but something here is wrong. I will have to investigate further....
    John T.
    3,067
    Yes the car was designed according to the Ackerman principles! It is also possible that there is movement of the lower link arm either through worn out silent blocs or through corrosion of the leading section of spline on the splined pin that passes through the lower link and both silent blocs.
    Cheers Gerry
    Apr 2014
    674
    Reporting back on this finally. The problem was one of the steering arms had sheared off its Woodruff key and was rotated down about 45 degrees. The P.O. had simply adjusted the tie rods to compensate for the change in toe angle. I had to remove the the brake backing plate to get a Pittman arm puller into the space to separate the tapered joint of the steering arm. There was evidence of grease on the tapers, so I cleaned everything thoroughly with brake cleaner before reassembly. Fortunately the steering arm Woodruff key is the same size as an SM water pump impeller key, so I had one in stock :-). The wheels now have about 20 degrees of toe out, but at least I am confident the Ackerman steering has been restored.
    John T.
    3,067
    Quote Originally Posted by citroenthusiast View Post
    Yes I have come across this problem before! When it occurs ( often from a very heavy shock from a pot hole or striking a kerb ) The arm pitman arm can move throwing Ackerman Principles out the window!
    Cheers Gerry
