Compresseur Constantine
Results 1 to 8 of 8
    May 2015
    4
    Default Compresseur Constantine
    Does anyone know anything about a supercharger that can be fitted to my ds21??
    Apr 2016
    Bedford, UK
    705
    Someone is asking the same question on Facebook. Is that you (Chris?)
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    Hi,
    Been discussed here before.
    Supercharged DS
    Supercharging a DS
    Cheers, Ken
    Jan 2012
    171
    for the bravehearted.......https://www.ebay.co.uk/itm/Vintage-C...-/252304347660
    seems to be missing the mounting brackets though
    I have also heard of people fitting garret T2 superchargers. Dealing with the extra underbonnet heat could be a challenge to the whole operation though.
    Apr 2016
    Bedford, UK
    705
    That rebuild was done about 5 miles from where I live! Doesn't make it any the more affordable though.......
    16,415
    That old supercharger... It is just a period accesory from what i can tell. Something driven by a single loose'ish 'V' belt isn't going to draw enough power .... to create much boost (look at the massive belts used by the hotrodders to drive there big superchargers .... and even they cause slipping issues).
    The best conversion I've ever seen is that blue DS there is pictures of somewhere. It has a CX2500 GTi Turbo engine fitted. The CX radiator and fan units are laying down across the nose where the spare wheel usually lives. Instantly you will have done away with most of the hardest bits. The cooling system is now large ... You could effortlessly tow your caravan with it if desired. The CX motor shoud just mount up as the block is pretty much the same. All you would need to do is figure out how to make the damn thing backwards.
    Future DS Project- Engine Swap? Diesel? Electric?
    have a read here though. You can buy drive reverses by the sounds of it.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    Fit a DS camshaft! It will run in the DS direction ie clockwise viewed from the water-pump end.
    Cheers Gerry
    16,415
    The oil pump will turn backwards The starter will spin backwards, and the flywheel sensors will need to be moved ... as ... as would possibly the pickup tooth on the flywheel.
    I wonder what else would be an issue
