DS23pallas
Results 1 to 10 of 10
Like Tree7Likes
  • 5 Post By GreenBlood
  • 2 Post By Arekisir
Thread: DS23pallas
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    367
    Default DS23pallas
    hi
    has anyone got experience with building from scratch new wiring harness for DS from fire wall to double headlights. require better bullet connectors with rubber insulators and colour coded sleeves.
    any suggestions for local suppliers would be appreciated - sydney or australia
    thanks
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,332
    David Gries in Victoria has...ph 03 9890 3266
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1970 DS21 Cabrio replica
    Citroen 1966 ID Safari (with 23 running gear)
    Citroen 1975 DS23 Safari
    1975 VW Kombi poptop
    1987 2CV
    Porsche Boxster S manual
    1988 Vespa PX200E
    Apr 2016
    Bedford, UK
    705
    If you're planning on doing it yourself, the connectors and coloured wire ends can be bought from Der Franzose and Citroen Classics amongst others. if you're looking to have someone else do the work, then you can buy looms for RHD cars. See the Citroen classics website for some examples:
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    8,184
    Paul I don't think Citroen Classics have the wing looms. . .
    They are pretty straightforward if you have the original loom as a guide, the fittings can be had by various suppliers with the coloured sleeves etc.
    I did my own, correct wire colours can be purchased from most auto stores locally, grey non-adhesive loom tape as used on early Fords i.e. https://www.ebay.co.uk/itm/Ford-Angl....c100011.m1850
    Test before wrapping. . .
    Invest in the correct crimping tool to close the connectors!!
    08 C5 X7 HDi very Noir
    691
    Beautiful work Chris...!
    Mark...
    Apr 2016
    Bedford, UK
    705
    Hi Chris
    Nice to know about that grey tape.
    I bought a replacement LHD loom from Darrin but I want to do a few mods, so what IS the correct tool? I know that getting a good quality tool is the way to go, but is there a particular tool for the older style bare bullets (the ones without a hard outer plastic shroud)?
    sydney-newport
    367
    Default DS 23 pallas
    this is the best excellent work many thank as it will assist. thanks all for the quick reply.
    8,184
    Hi Chris
    Hi Paul,
    I took one of the bullets to our local Jaycar (Electric components) store and the sales guy sold me these. The jaw closes over both the wire and insulation in one hit. The jaw suits three sizes the smaller being most suitable. Decent wire strippers makes the task easy and repeatable.
    Attached Thumbnails Attached Thumbnails DS23pallas-bullet-crimp1.jpg   DS23pallas-bullet-crimp2.jpg
    Apr 2016
    Bedford, UK
    705
    Those are serious crimpers - but i bet they are satisfying to use! I will have to look some out.
    May 2014
    104
    I used 4mm bullet connectors, heatshink and silicone tube to replace degraded rubber - see photo.
    I could not find "mauve" heatshrink so used pink electrical tape. All coloured heatshrink overloaded with clear glue lined heatshink which covers the whole female connector.
    GreenBlood and ramonm like this.
