CX fuel pump wiring
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By gerrypro
  • 1 Post By rmac
Thread: CX fuel pump wiring
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    741
    Default CX fuel pump wiring
    Has anyone replaced the electrical cable to the fuel pump in a CX? Are there any hints/tips please?
    Cable to pump on my Familiale appears to have a break somewhere along the cable causing an intermittent fault.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    10,380
    No idea but, FWIW, I'd just run a parallel for a while to check whether that existing wire really is the intermittent source. Perhaps I'm lazy....
    Glad there's progress!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    741
    We have only been able to start it with a parallel line so it seems to be the current culprit.
    Current Cars
    1991 Mazda E2200
    10,380
    Hmm. Is there a flex point or does it have its own relay lurking somewhere I wonder? Still, running is RUNNING!
    Renault 4CV 1951
    Renault R8 1965
    Fellow Frogger! andrewj's Avatar
    Margate
    372
    Or a terminal / relay contact burnt and gone high resistance?
    Try measuring the voltage at the pump when trying to start- bypass wire vs existing wire. Is there excessive voltage drop on load on the existing wire, or just no volts = open circuit?
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,958
    Quote Originally Posted by rmac View Post
    Pun intended??????
    JohnW likes this.
    Cheers Gerry
    Jun 2014
    Frankston
    25
    Hi, The fuel pump power is supplied through a relay of which (from memory) there are two versions,
    1. has a single set of make contacts which supply both the fuel pump and the high side of the injectors.
    2. has two sets of make contacts one set for the fuel pump and the second set for the injectors.
    These relays are common to a number of other Bosch Injection equipped vehicles and are often referred to as Big Blue because of their size and cover colour but I'm sure I've seen them back as well.
    16,166
    Yes, check the blue tachomatric relay ... Infact just pop its lid off and squeeze the contacts manually together. If the fuel pump runs, the wiring is fine. The usual culprit is the wiring connectors onto the tachometric relay as opposed to the relay itself.
    741
    Thanks for all the tips. The blue tachomatric relay was working fine with power being run, via a separate cable, to test the fuel pump. As it was giving 12 volts at the relay but not at the pump the wiring has been replaced and we now have GO
    JohnW likes this.
    Current Cars
    1991 Mazda E2200
