Xantia SX II: Transistors for (Valeo) fan control
Results 1 to 7 of 7
    Dec 2011
    12
    Default Xantia SX II: Transistors for (Valeo) fan control
    Hi,
    Back a few years ago I had a Xantia VSX series 1 and repaired the a/con fan when it stopped by replacing the transistors. I bought this series on Wednesday and found that the fan didn't work so I pulled it out and removed the controller and then then the resistors. The trouble is in 10 years I'd forgotten where I'd sourced the transistors. Can anyone help?
    This car is in excellent condition and well maintained. I am wanting to sell me C3 hdi if any interested.
    Ted Newing (Cit owner for 55 years)
    10,797
    I reckon I got mine for that exact failure in the BX from Jaycar electronics in Perth - but no idea of spec I'm afraid. They are on Morphet St in Adelaide.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Kapunda
    457
    Hi Ted, RS Components are very good too. I have quite a few at home if you give me a rough spec ie current requirement.
    woody. PS You have not answered my message about the Petrol Cap.
    Dec 2011
    12
    Well what do you know I just discovered the following url:
    xantia ii air blower - Google Search
    Problem solved!
    Dec 2011
    12
    HI Brian! Hope you and Irene had a good time at the CitIn at Dalby.
    Thanks for the info. My son Tim also had found a solution.
    I've had to take the NS front door off again because I'd stuck the trim 25mm too high beside which when I'd painted it I hadn't used enough paint.
    The market for Ds (indeed any car) doesn't look too promising at the moment. But that'll change.
    For some reason I did not get your message re petrol cap. Could you send it again please.
    Griesy says he has one.
    Ted
    Dec 2011
    12
    Thanks John, Jaycar are not really that helpful.
    Ted
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,927
    Yep the MJ11016 is a bit special. I am sure any other darlington PNP 30A power transistor would be just fine.
    Cheers, Ken
