Thread size for 3.5mm hydraulic end fittings...
    Apr 2018
    2
    Default Thread size for 3.5mm hydraulic end fittings...
    Hi, does anyone know what are the thread size for the end fittings on 3.5mm hydraulic lines? Or shall i say what size are the end fittings...?
    This is for a C5.
    Thanks.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    Standard M8 thread for the fittings on the 3.5mm pipe on the CX, Xantia, XM.
    Don’t know about the C5 as that’s a bit modern for me, but would imagine it’s the same.
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2014
    Phoenix, Arizona USA
    676
    Quote Originally Posted by marc61 View Post
    FWIW,, standard M8 = M8 x 1.25 pitch
    John T.
    9,777
    The C5 is different to the earlier cars and I don't think it uses the old style rubber pipe seals. The fitting for the Xantia/XM would be M8x1.25, but it appears to be different on the C5's 3.5mm piping. Some of the suspension piping uses bonded steel/rubber rings (#4) instead and that also made an appearance on some high pressure lines on late Xantia. The best option is likely salvaging the parts required from a wreck.
    Apr 2018
    2
    Thank you gentlemen. I suspected it was M8 but was not sure. I guess we will have final confirmation once i rip apart the pump. Car is not rising. The pump is running but not pumping. I suspect electrical faults, ie the solenoid valves are not opening at the pump. I have Lexia connected but cant clear the fault. I will post update after i do more experimenting.
