CX 2400ie needs ignition leads
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    750
    Default CX 2400ie needs ignition leads
    Does anyone know if a set of new ignition leads is available in Australia. Needed for a 2400ie - or will I have to source from Europe?
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    Can you make up a set from off the shelf after market leads?
    Cheers Gerry
    750
    Thanks for the suggestion Gerry. It could be possible I suppose but may be difficult to match as the leads are neatly laid out in a 'rig' that takes them across the injection intake.
    Current Cars
    1991 Mazda E2200
    3,069
    It used to be possible to buy over length ones and then trim them back and refit distributor cap end terminals for Ds. Is there a special terminal for the coils and would it be possible to refit them?
    Cheers Gerry
    16,426
    Have a look at CX bassis, I purchased a couple of sets through them a few years ago for an inexpesive price. They have the molded built in plug extenders etc... Failing that, try and match up an existing set with built in extenders (eg: the corrola? ones that fit a DS perfectly).
    I've always just take the Citroen CX leads that don't have moulded extenders built in into the local auto parts shop and purchased universals that match!
