Xantia steering rack leak rly
    Ici.
    2,560
    Default Xantia steering rack pipe leaking
    Hi just detected ome of the inlet pipes to rack is leakng fairly enthusiastically.
    Easy enough getting access to and putting a spanner on, obviously I'll find out if its cracked when removing but wanted to know in advance if there's a rubber seal in there and what size it would be?
    I changed a lower arm bush recently and it still has a clunk, I can't help thinking the pipe leak might be from some strain on the suspension from this bush problem although the hydractive is kaput and only behaves randomly and so when the car hits a bump sometimes the suspension is severely harsh and I guess this might be putting strain on the pipes also.
    Steven
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    Check this thread that I added to recently.
    Xantia Power Steering Gusher
    Cheers, Ken
    Ici.
    2,560
    Thanks Ken, this car is/was my daily but the D is going to get it's rego done this week. So there might be some paper swapping hopefully! I bought some bushes after reading your thread thinking job to be done; I guess finding a pipe might be hard work. I guess soldering one up might be a no no.
    I think the Xantia noticed I was doting over the D too much and decided it was time for retribution!
    10,783
    Limelight deprivation. A common problem.....
    Weren't there threads in the past about the V6 cars cracking hydraulic pipes to the rack?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
