Steering rack
Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By Roger Wilkinson
  • 2 Post By robo
Thread: Steering rack
    Fellow Frogger! robo's Avatar
    147
    Default Steering rack
    Hi Iím in the process of removing my steering Rack to get it refurbished,
    I have removed it fro the car but cant get the steering rods off at the Center union
    Sep 2012
    Somewhere near Mudgee, NSW
    329
    Hi
    The fitting there is on a taper from memory.
    Run the nut back on till level with end of stud.
    Place a piece of wood on it and give it a sharp tap.Or use a puller to put a bit of pressure on it and likewise a sharp tap should release the taper.
    147
    Quote Originally Posted by Big Frog View Post
    Hi
    Do you mean it is like a ball joint taper? I tried a puller but the one i have did not grip properly.Steering rack-84e74240-a6b4-4d5a-b149-7f54db60c0ba.jpg
    Jun 2015
    Ashburton
    199
    Just did that job. We needed a hydraulic puller to get it off. Yes it is tapered
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,346
    Try twisting it.
    Roger
    147
    Try twisting it.
    Roger
    Ive tried twisting it but no go and I a bit scared how much force to put on it, don’t want to break anything.
    Ici.
    2,560
    Can’t you just leave them on and let the pro sort it out? I left mine on when I sent it off! Zip tie them to rack, rotate the spline on shaft to push out the fluid so it doesn’t leak everywhere too.
    147
    Yer think that may be the go.
    Warrnambool
    2,346
    You can put a fair bit of force on it. It won't break easily. Heave on both arms at the same time. Pullers are for situations where you can't twist it.
    Roger
    Manic GT likes this.
    Apr 2014
    Phoenix, Arizona USA
    676
    Get a cheap pitman arm puller like this. It will work a treat.
    https://www.ebay.com/itm/Tie-Rod-End...oAAOSwH09ZHPFX
    John T.
    147
    Thanks guys after a night with some lubricant i gave it a twist and vit popped off easy..
    1000+ Posts garyk's Avatar
    Feb 2011
    1,053
    Quote Originally Posted by robo View Post
    Hmm.
    Are we allowed to discuss intimate things like this on AF?
    Lubricant, you say?
    Once upon a time:
    Many R4s (incl. fourgonnette), R5LS, R16TS.
    GS 1015, 1220, sedans and wagons.
    CX 2200, 2400.
    ID 1966, 1969, DS21H, DSpecial, DS23 Pallas.
    C5 2002, 2004 petrol and diesel.
    D Special 1974
    Xantia Activa 1998 (look out Gulargambone)
    GS 5 speed sedan (what a tale)
    1986 2CV6
    CX25GTi 1985 auto
    CX2500 IE Pallas 1985 auto
    DS23EFI 1975 Pallas
    And now:
    C5 2.2 HDI 2005 wagon
    DS23 1973 Pallas
    147
    [QUOTE=garyk;1566500]Hmm.
    Lubricant, you say?[/QUOTE\
    Maybe i should have worded that differently
