2CV Starter Motor
  • 1 Post By COL
Thread: 2CV Starter Motor
    Kapunda
    457
    Default 2CV Starter Motor
    Sad to report the one on my Dolly has packed up, I think those difficult hot starts on the way home from Dalby did it! On removal I discover that it is nameless .However it is quite a simple thing so I soon discovered that the brushes are worn out, the dimensions of the Brushes reveal that it is an ISKRA (2CV Shop}.These are available however they are spot welded on which looks a bit tricky. Alternatively I could get a new one, Der Franzose looks like the best deal. All advise welcome.
    Woody
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,066
    If I was doing this repair, I would be removing the old brush and its tail.
    Clean up the area with some fine emery, apply some bakers flux and tin with soft solder. Would then tin about 10mm of the brush tail and then solder the two together.
    Holding the tail of the brush with a pair of long nose pliers where the tinning stops will stop the heat travelling down the brush tail and sucking the solder down the tail.
    You will need a decent sized soldering iron like the old style Berko's
    Hotrodelectric likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    canberra
    290
    Random question Brian. Did you buy your Dolly from a guy in Norman Park about 15 years ago ?
    Kapunda
    457
    That was not 2b, I got it from a bloke in Adelaide about 15 moths ago.
    Woody
