Change oil in automatic C5 Citroen 2004 V6
  • 1 Post By pugwash
Thread: Change oil in automatic C5 Citroen 2004 V6
    Apr 2017
    Gunnedah
    15
    Default Change oil in automatic C5 Citroen 2004 V6
    Hi
    Can anybody assist in how to change oil in automatic and refill
    Thank You
    Rex
    Oct 2014
    Brisbane/Australia
    361
    Look up AL4 gearbox oil change. There are lots of how to's floating around.
    8,117
    Quote Originally Posted by dcc236 View Post
    Wouldn't the V6 have the ZF4HP20?
    08 C5 X7 HDi very Noir
    8,207
    The 4HP20 holds about 8 litres, but draining will only lose 3L.
    tweed heads
    1,439
    My son had one of these once ,i recall googling for the detail ,the level plug is on the back of the box near the exhaust ,as the engine has to be running in park to test the level ,,if you don't have a hoist you will have to set it in high put some stands under it for safety then slide under keeping away from the hot bits ,just about when you think its getting uncomfortably hot the thermo fan will cut in blasting you with hot air ,a 10mm socket with a couple of extension s and a uni douse the job ,,or you could just measure how much came out and put the same amount back in ,.ours had a leak into the coolant via the heat exchanger on top of the transmision, once fixed, we had to top up to level ,so didn't drain oil ,you are not going to get it all out with one go, so will have to do it a few times ,its worthwhile ,pugs
    diode1111 likes this.
