DS21 rear brake lockup - again
Results 1 to 25 of 25
Like Tree3Likes
  • 2 Post By David S
  • 1 Post By tresbon2
Thread: DS21 rear brake lockup - again
    Mar 2003
    337
    Icon5 DS21 rear brake lockup - again
    Today I went to test my car to see if a couple of new tyres had fixed the extreme shuddering problem at last.
    I barely got through my gates when the LHR brake locked up This has happened twice before. The first time chamfering of the linings fixed it. The second time I checked and adjusted the shoe alignment and found that the RHR brake was covered inside and out with a film of thin grease. I also replaced the cylinder o-rings although there were no leaks visible. I could only think that the oil/grease was from a faulty bearing seal.
    This time the LH and RH interiors are quite clean.
    My question is what can I do next and how critical is the shoe alignment?
    Don
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    Apr 2014
    Phoenix, Arizona USA
    607
    If the shoes themselves are contaminated, it could cause them to grab. Consider replacing the shoes. Shoe alignment is not that critical, all that happens is the shoes will wear unevenly if you don't adjust the eccentric on a regular basis.
    John T.
    54 TAV Legere; 61DS19 LHM BVH (son's); 71DS21 BVH; 73SM 3.0; 73SM EFI (Megasquirt); 73SM 3.0 (other son's)
    Mar 2003
    337
    Quote Originally Posted by citroenthusiast View Post
    Thanks John. The shoes show no sign of contamination and I have no idea how to fix this problem. In 60+ years of playing around with old cars I have had just about everything go wrong but never had this trouble with any other cars.
    Don
    9,310
    Have you considered the condition of the flexible hoses? Bad hoses with some internal failure could cause random behaviour.
    JohnW and Hotrodelectric like this.
    Mar 2003
    337
    Thanks David. No I haven't thought of that and my local DS guru did not mention it either. I had been going to ask on this site whether I should consider replacing the hoses because I suspect they are 47 years old. I didn't because it was a no-brainer; of cause I should do it.
    Don
    San Diego, California, USA
    3,485
    Great suggestion. I've heard of it happening on "regular" old cars, didn't think it would happen on an LHM D.
    Mar 2003
    337
    SUCCESS! I should have checked it before but I simply adjusted the shoes as close as possible to the drums and that has cured the problem. Another lesson learned.
    Don
    Mar 2003
    337
    Quote Originally Posted by tresbon2 View Post
    Don
    Woe is me. The lockup problem is back! It was absent for almost 100kms but today, following my cleaning the front brakes and deglazing the pad surface, I started on a test run but did not get further than the bottom of my driveway before the lockup on the same old wheel happened again. And I really do not know what else to do. A brake expert has told me that if it was caused by a faulty hose then the brake would lock on. In this case it releases as soon as I release the pedal.
    Has anyone else had this problem?
    Apr 2014
    607
    It has happened to me from a leaky wheel cylinder. The LHM from the cylinder contaminated the shoes so when I rebuilt the wheel cylinder the contaminated shoes on that side really grabbed at the drum. In my case the problem went away eventually after I burned off all of the contamination (back then I was too cheap/poor to buy new shoes), but I did have to drive carefully for several weeks (this was my daily driver at the time).
    John T.
    Mar 2003
    337
    It seems that I will have to take it to a brake specialist.
    I have one not too far away and I will drive extra carefully. I have noticed that there is no lockup in reverse, when the leading shoe becomes the trailing shoe and vice-versa.
    I think that I will have another look in case something is wrong with one of the springs, despite them all appearing normal last time I looked.
    Apr 2014
    607
    One last thing to check is to make sure the front brakes are properly bled. Air in the front circuit could conceivably delay the application of the front brakes, leading to the appearance of the rear brakes locking up (when in fact they are just doing their job). Admittedly, this is a long shot since there would have to be quite a bit of air for this to happen, but at least it is easy and inexpensive to do....
    John T.
    Mar 2003
    337
    Since my last post I checked the RH side brake and noticed that the shoes needed adjusting closer to the drums. I did not really think that this would fix the problem (it is only the LH side which locks up but releases as soon as I release the brake pedal) and it didn't.
    Fellow Frogger! neural revolt's Avatar
    Frenchs Forest/Sydney/Australia
    311
    Another long shot...
    I had a problem with a Renault Virage; one of the rear brakes would lockup in reverse but okay in forward motion.
    Was caused by the brake backing plate moving slightly when brakes applied. The mounting holes in the backing plate had elongated and no amount of tightening the retaining bolts would stop the movement. Had to weld up and redrill the holes.
    Past Frogs:
    Alpine White 1967 R10 (round eye)
    Alpine White 1972 R16TS
    Blue 1978 Virage Wagon
    Current:
    Red 2009 Clio RS 200 CUP
    Mar 2003
    337
    Thanks to all for your ideas. I was getting ready to replace the brake hoses, just in case, but was not confident that this would help. So I had another go at adjusting the shoes as per the manual. The tolerances required are very small - .1 of a mm. Well so far (6km) so good. Now for a longer test.
    Apr 2016
    Bedford, UK
    608
    There is a special tool for adjusting the rear brake shoe clearance. You can easily make one up. Have a look here:
    and maybe contact Colin Smith for dimensions etc.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Mar 2003
    337
    I made one after the first time this problem occurred. It was so simple even I could do it!
    10,382
    Why would the shoes lock up if the clearance to the drum is excessive? Or have they been over-adjusted all the time?
    Just curious.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Mar 2003
    337
    Just curious.
    I have no idea! When I adjusted the shoes the second time I also filed a bit more off the leading edge of the leading shoe. Maybe that is what did the trick -time will tell.
    JohnW likes this.
    Mar 2003
    337
    Well, it lasted for almost 50kms but next time I started on a trip the lockup returned. So now I intend to change the brake hose, which from the history of this car is probably the original. I need a 9mm special spanner; the one like a ring spanner but with a bit missing to fit the pipe. I can't find any locally - can anyone suggest somewhere in Australia to try?
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,310
    Is this what you are looking for? I note the text says 8 and 9 mm but the image is of a larger one.
    SPANNER FLARE NUT METRIC 8MM X 9MM - JBS Tools
    Every day is a good day
    10,382
    Quote Originally Posted by FIVEDOOR View Post
    Essential tool for an owner of a hydraulic Citroen!
    Renault 4CV 1951
    Renault R8 1965
    10,382
    Original? Good grief! I had serious one wheel lockup on my Renault 4cv some years ago. It was 'only' a 20-year old hose, so far from original, which failed internally in such a way that a flap of rubber was acting as a one-way valve. I now use new hoses made by the local brake place, which has a truly amazing range of end fittings.
    Maybe the lockup, if internal failure, is related to the volume of fluid moving on brake application - very tight clearances means very little fluid to operate the 'valve' in the hose. drive a bit and the clearances will open up..... Just a thought.
    Renault 4CV 1951
    Renault R8 1965
    Kapunda
    438
    Go for a Snap-On spanner, definitely the best.(IMHO) and the dearest!
    Woody
    Ici.
    2,408
    I'd be taking the brake cylinders off and having a look at the pistons and seals. I guess if the hoses are old you might be getting air in there but you'd be seeing fluid most likely. Other than there might crud in the lines, migt be time to take the rear height corrector off and give that new boots and a thorough clean. New brake shoes if they are getting thin or reshoe.
    bob
    bob is offline
    May 2001
    Skipton
    2,234
    G'day,
    a long long long time ago I had a '53 Customline, this also had a similar lock-up problem - but it wasn't 40 years old way back then...
    The local brake place advised to rough up the brand new lining with a rasp and drive through the "sensitive" time - it worked !!
    cheers,
    Bob
