Bubbles in fuel line
Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By jaahn
  • 1 Post By seasink
Thread: Bubbles in fuel line
    St Helens Tasie
    603
    Default Bubbles in fuel line
    Doing a little maintenance today ( change air filter etc.) After I finished, started the car up and looked over the motor, OK, running smoothly. Then I noticed a tiny stream of bubbles in the fuel line from the filter, over the top of the inlet manifold. When I revved the engine a mass of bubbles went through the line. Is this anything to worry about? The car runs well.
    Btw, the bottom sponge part of the filter was in tatters, lumps of the sponge were pulled out. Also there was quite a bit of rubbish and insects at the bottom. The local parts bloke says it was mice in the filter. He has had the same experience.
    Allan
    Newcastle
    2,623
    Hi
    If it is a diesel then no bubbles should be seen in the fuel line. If the bubbles have not cleared then you probably have an air leak at the filter. Sort it out before it cause problems.
    Jaahn
    Greg likes this.
    8,777
    If you bled the filter (screw on top) then bubbles should be minimal while the filter fills, then stop.
    Greg likes this.
